Sounds very nice! What 1/4 times have you run? Where?
Where in NZ is the Bilstein susps available (or where's a good place to get
them)? What size struts/shafts are they? Cost (approx)?
Regards,
Phil
BTW Greetings all from a list newbie
> Date: Wed, 06 Jun 2001 22:175 -0000
> From: daniel.wilson@db.co.nz
> Subject: OK Here Goes
> Cold air box, pod filter, and new plenum, bored out throttle body to
> 64mm (almost straight through), 600cc injectors (800cc for drags),
> modified fuel rails (larger and fuel fed from both ends), huge bosch
> in tank fuel pump, rising rate fuel regulator, alcohol and water
> injection, EJ22 BPM stroker kit, balanced and blue printed, very
> large con rod bolts, spigot the o-ring the block, Subaru EJ25 Outback
> heads (large bucket, solid lifter, inlet ported to match EJ20
> manifold), strapped heads, Group A plus cam profile, ported STI
> manifold, tuned length extractors, standard TD05 turbo (mounts
> twisted and right now being totally modified with custom impeller's
> and housing's), 3" mandrel bent stainless exhaust no cat and Borla
> muffler, block runs no sleeves because the sleeves keep splitting
> (the alloy block has a special coating), on spark plug coils, new
> link II computer and all the options and big front mounted oil cooler.
> RS twin turbo clutch and gearbox retrofit, and new rear LSD (not twin
> turbo or late model).
> Bilstein Group N rally suspension front and rear (with progressive
> springs).
> Slotted rotors and comp 9 race pads.
> Changes to come:
> Dog box, bigger wheels and Porsche GT3 brakes front and rear, strut
> brace, complete the Nolathane bush changes, modify the strut system
> to allow adjustable platform and finally up rated sway bars.
> I am sure I missed stuff, but I am sure that will do.
> Dan
