I think I had the same problem as you Rob.
I have a boost gauge and my boost was fluctuating from 9psi to about 5psi. It
would work fine for sometimes a couple of months and then suddenly cut itself
down to 5psi like I hit a switch! I figured it was my factory boost
controller causing it but when I installed a USED one while the problem was
occurring nothing changed!! I believe it was Pete in our group here told me
the part # to replace which turned out to be the PCV Valve. Unfortunately by
the time I got the part the stupid car was already running a full boost again
so I when I changed it I couldn't tell if it solved my problem only time would
tell. So far it's been about 3-4 mths and boost has never dropped off since!!
So I suggest changing the PCV valve first since it's only about $10.00 and
see what happens.
Fred
------------------( Forwarded letter 1 follows )--------------------
Date: Wed, 29 Aug 2001 00:19:28 -0000
Sender: sentto-2208544-4126-999047133-WHITMO02=CN.CA@returns.onelist.com
Reply-To: BC-BFLegacyWorks@yahoogroups.com
Subject: [BC-BFLegacyWorks] Re: Help Slow Tegacy Turbo
Your solenoid is most likely just not working. Get a manual
controller, it does a better job than the stocker even if it were
working.
--- In BC-BFLegacyWorks@y..., rob440@h... wrote:
> I have a 93 uk spec 20L legacy turbo
> ive only had it a month and was well impressed with the
performance ,
> But it now seems to have lost all boost presure ,
> Everu now and then it seems to mend itself and go ok for a while
> and some times it seems to surge , but moastly it just feels flat .
> Ive checked all visible hoses for splits , cleaned out the
waistgate
> solenoid . i can move the waistgate and it springs back ok
> Sometimes i can here the turbo spin up , sometimes i cant
> any ideas please
> thanks
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/zoU8wD/4m7CAA ... /XoTolB/TM
Help Slow
