Legacy Air suspension and XT6 air suspension
ciper
Post by ciper »
I have a chance to get a very low mileage xt6. The biggest issue is a non functioning air suspesnion. My question would be, is the air suspension from the legacy and xt6 the same parts?
More specifically I guess I want to know if I could use struts and strut tops from a legacy? I guess it wouldnt be too hard to find an old XT for the swap but a legacy would be easier to find.
The xt6 is a 5 speed and it only has less than 100k miles
I sorta don't think it would work as the Legacy and XT6 are completely different generation of car.
You're best bet would be to probably use struts & springs for the XT6.
I'd go over on the 80's side of the USMB and ask over there. They seem to be pretty good place for the older stuff.
ciper
Post by ciper »
I dont know, the xt was out until 1991 and the air suspension system looks very similar. The car I speak of is an 89. The XT has to have the coolest interior of any legacy I have seen, just slightly dated.
There is probably similarities between the two.
The legacy was supposed to be completely gone over and designed from the ground up. So I don't think there was a lot of stuff that "directly" carried over from before. There's probably similarities, but dimensions may not be the same.
You mean subaru right....not legacy ;)
ciper
Post by ciper »
Well, now you guys know how really tired I am. Ive been at work now for a second day straight.
No worries man :)
