Head bolt torque
-K-
Head bolt torque
Post by -K- »
Can someone give me the steps and torque for the head bolts. Turbo please, my haynes (POS) manual lists a in-lbs final torque that is less than the step before it. "we smoke crack then do a compleat tear down and rebuild." Well, my cheap ass bought it....
thanks
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
IggDawg
Post by IggDawg »
The thing is that they want to torque it down, then un-do it a little bit, then torque it down again... all this to make sure the seal is proper. IIRC, you torque them to a certain spec and then tehy tell you to do another "quarter turn" after that or something. check it out again. the process is so damn involved I'd hate to think it was incorrect.
IggDawg is cool.
-IggDawg
1994 Barcelona Red SVX LSi.
1990 CRX Si (for sale)
-K-
Post by -K- »
It says to torque then loosen, then torque to 27 ft-lbs, then torque to 168 in-lbs. 27 ft-lbs is more than 168 in-lbs so WTF, am I missing something?
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
-K-
Post by -K- »
There must be someone with a FSM that can tell me???
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
magicmike
Post by magicmike »
ok, I dont have the specs but I can explain why it might look funny to you.
Basically you go around and torque the head bolts down with a higher torque spec so you are basically stretching the bolts out a little. Then you back them off and re-torque them to the propper torque. If you dont "break in" the head bolts the pressure will actually stretch the bolts a little and cause premature head gasket failure. So all this process does it stretch them in advance :shock: I have the procedure in one of my books I'll look it up for you
Mike
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
this is also why subaru says to use new head bolts.
You will heard different things from different people on that issue.........but subaru's official stance on things is that you shouldn't reuse them.
magicmike
Post by magicmike »
Yes, thats true, I just had my engine rebuilt and I bought all new head bolts and the bolts that connect the two halfs of the motor together (short block) The price was around $180 dollars ish....
I knew it would be a pain in the ass to put the heads on so I had my machinest do it, all and all he didn't charge me any extra :D
Mike
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
-K-
Post by -K- »
Ok, thanks
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
georryan
Post by georryan »
Is it ok to use the old head bolts, though? Have you guys done it? Should I really be worried if I do?
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
Yes, reusing the head bolts is fine. I reused mine.
JasonGrahn
Post by JasonGrahn »
Once is good. Twice is pushing. Three times is a no no.
-Jason Grahn
206er
Post by 206er »
use the FSM's method which is available online.
I also reused my head bolts, just put oil on them like it says to do.
