Ben Lam FPR question
Locked
ssspoon@aol.com
Post by ssspoon@aol.com »
Hey Ben, seems like there is some confusion about your search for a fuel pressure regulator (FPR).
Yes, there is a stock FPR and it does a good job at stock or near stock boost levels.
If you are contemplating boost levels above that which the stock FPR can feed fuel then you probably will want a BDFPR, a boost dependent fuel pressure regulator, that self adjusts fuel pressure upwards as needed, to match fuel requirements of increasing boost levels.
Larry Witherspoon
b.lam@usa.net
Post by b.lam@usa.net »
Hay Larry, thanks for your reply, and I would like to know more about
the BDFPR, Where can I got more information and where can I buy one
of them???
Are they just replace on the Stock FPR or add-on with the Stock FPR?
Thanks for shear your experance!!
Ben
Locked
