Message: 5
Date: Wed, 19 Sep 2001 12:510 -0400
Subject: Re: SHORT THR
Would you guys happen to have the part # of the STI Short Shift Kit for our
car? My local dealer is trying to tell me that they don't even make one for
my car! They said they only have one for the WRX.
How much did the installation cost?
thanks guys
Fred
Part Number's
93-2001 IMPREZA PARTS
Part Name Part Number.. Quantity
22B Bolt Subaru 57728FA041 2
22B Bush B(L/Link) 20251AA050 1
22B Bushing Transverse Link Front ST2022044000 1
22B Bushing Transverse Link Rear ST2022044010 1
22B Clip Subaru 57728FA020 6
22B Fender 57110FA050 1
22B Fog Lamp Cover Set (LH and RH) S075580070 1 Set
22B Front Bumper Assembly S075580080 1
22B J Nut 57738KA000 2
22B Lateral Link Assy-F S075580140 1
22B Lateral Link Assy Rear RH S075580150 1
22B Lateral Link Assy Rear LH S075580160 1
22B License Plate Bracket S075580210 1
22B Pillow Ball Bushing 20252PA000 1
22B Seat Right Front 64101FA680 1
22B Seat Left Front 64101FA690 1
22B Seat Rear Cushion 64401FA410 1
22B Seat Rear Seatback 64451FA810 1
Aero Splash Front Set J1017FA012 1 Set
Aero Splash Rear Set J1017FA015 1 Set
Air Filtration Kit G3210FC000 1
Air Intake Fender Plug (As Found On 00-01 RS) 46059FA000 1
Aluminum Control Arm RH 20200FA060 1
Aluminum Control Arm LH 20200FA070 1
Aluminum Control Arm Attaching Links 20217FA101 1 Pair
Aluminum Engine Hood 57220FA130 1
Alternator/Power Steering Tension Bolt 800508220 1
Alternator Tensioner Bolt 34435AA030 1
Alternator Tensioner Nut 34436AA000 1
Battery Warmer J6010FS000 1
Black Stars Front Grill Badge 91053FA000 1
Brakeline, Rear Disk RH (RS) 26531AA041 1
Brakeline, Rear Disk LH (RS) 26531AA070 1
Brakeline, Rear Drum(OBS and L) 26531AA020 1
Camber Adjustment Bolt, RS Front 20540AA090 1
Carbon Fiber Park Brake Handle (Manual Transmission Only) C1010FC121 1
Carbon Fiber RS Interior (Automatic Transmission Only) J1310FA130 1 Kit
Carbon Fiber RS Interior (Manual Transmission Only) J1310FA140 1 Kit
Carbon Fiber Shift Knob (Manual Transmission Only) C1010FC121 1
Carbon Fiber Strut Brace E4010FA100 1
Center Console Extension (Gray) J2010FC100ND 1
Clear Corner Lens (RH) 84451FA020 1
Clear Corner Lens (LH) 84451FA030 1
Door Lock Timer 88201FC030 1
EJ22T Turbo Longblock 10103AA310 1
Embroidered Impreza Trunk Mat J5010FS100 1
Engine Block Heater A0910AS000 1
Extended Arm Rest Beige J2010FA100GA 1
Extended Arm Rest Black J2010FA100OE 1
Extended Arm Rest Gray J2010FA100ND 1
FHI 18mm Sway Bar Rear 20450FA020 1
FHI 20mm Sway Bar Rear 20450FA040 1
FHI Sway Bar Bushings For 18mm And 20mm Bars 21047GA671 1 Pair
Forester Dual Cupholder (Dark Grey) 66150FC000OE 1
Forester Glovebox (Replaces Passenger Airbag With Modification) ST6600079000 1
Front Axle Housing (RH) 28012AC040 1
Front Axle Housing (LH) 28012AC050 1
Front Axle Oil Seal 28015AA07 1
Front Axle Oil Seal 28015AA021 1
Fuel Vapor Cannister 42036AC020 1
Gas Filler Area Drain Tube 09501J360 1
Gasket, Cylinder Head (SOHC engine) 11044AA521 1
Gasket, Exhaust Header (SOHC engine) 44022AA020 1
Gasket For Second Airbox MY99 RS 16553AA041 1
Gasket, Intake Manifold (SOHC engine) 14035AA382 1
Gauge Pack (Gray, Electronic) H5010FA001 1
Gauge Pack (Gray, 3 gauges) H5010FA034 1
Gauge Pack Housing (Gray) H0017FC910OE 1
Headlamp Washer Nozzle 86636FA040 1
Headlamp Washer Switch 83013TA000 1
Headlamp Washer T Valve 786634010 1
Impreza RS Full Front End Cover M0010FS140 1
Impreza RS Hood Cover Only M0010FS111 1
Impreza 2.5RS Logo Floormats J5010FS001OE 1 Kit of 4
Impreza RS Performance Muffler And Intermediate Pipe Kit SOA8377500 1 Set
Impreza Sedan and Coupe Spoiler - Aegean Blue E721FS000AB 1
Impreza Sedan and Coupe Spoiler - Brilliant Red E721FS000BR 1
Impreza Sedan and Coupe Spoiler - Caribbean Green E721FS000CG 1
Impreza Sedan and Coupe Spoiler- Crimson Pearl E721FS000CP 1
Impreza Sedan and Coupe Spoiler - White E721FS000GW 1
Impreza Technical Overview Kit MSA5AV140K 1 Kit
Impreza Pre Delivery Inspection Kit MSA5AV139K 1 Kit
Inner Fender Plastic Wheel Arch (RH) 59110FA000 1
Inner Fender Plastic Wheel Arch (LH) 59110FA010 1
Internal Trunk Release Handle X5751FA000 1
Key Blanks 57430AA140 1
Keyless Entry Upgrade H7110FS101 1
Legacy Turbo Crossmember 200100AA120 1
License Plate Lamp Housing 84301FA000 1
Lightweight Bumper Beam Front 57760FA400 1
Lightweight Bumper Beam Rear 57760FA192 1
Locking Gas Door (Flat Door) 57601FA000 1
Locking Gas Door Cable 57330FA030 1
Locking Gas Door "Fuel" Tab 57346AA010ML 1
Locking Gas Door Spring 57651FA000 1
Locking Gas Door "Trunk" Tab 57346AA000ML 1
Lugnuts, Chrome OEM (RS) 623006021 1 Set
Main Body Wiring Harness Front 81222FA030 1
Mudflaps (front will not fit RS) J1010FA200 1 Kit of 4
Nut-clips To Mount Splash Guards/Rear Spats/Mudflaps 91086AA000 2
NGK BKR6E-11 Spark Plug 22401AA310 1
Outback Sport Struts (Front RH) 20360FA360 1
Outback Sport Struts (Front LH) 20360FA370 1
Outback Sport Struts (Rear RH) 20310FA860 1
Outback Sport Struts (Rear LH) 20310FA870 1
Oil Cooler Kit Cover Cp Thermo 11054AA010 1
Oil Cooler Kit Hose 805918010 1
Oil Cooler Kit Hose 807611090 1
Oil Cooler Kit Oil Cooler 21311AA010 1
Oil Cooler Kit Oil Cooler Connector 21317AA021 1
Oil Cooler Kit Oil Cooler Pipe 21328AA040 1
Oil Cooler Kit PCV Connector 21369AA040 1
Oil Cooler Kit PT650297 Hose 807611031 1
Oil Union Threaded Nut (Oil Filter Screws Onto This) 15018AA021 1
Oxygen Sensor, RS Front (1998) 22641AA011 1
Oxygen Sensor, RS Front (1999-2001) 22791AA00A 1
Oxygen Sensor, RS Rear (1998) 22690AA420 1
P1 Front Spring 20330FA160 1
P1 Rear Spring 20380FA450 1
P1 Front Left Strut 20311FA960 1
P1 Front Right Strut 20311FA950 1
P1 Rear Left Strut 20360FA960 1
P1 Rear Right Strut 20360FA950 1
P1 Front Grill 91065FA200NN 1
P1 Steering Wheel (STI) 34311AE200 1
P1 Front Right Seat Back Rest 64152FA740MU 1
P1 Front Left Seat Back Rest 64152FA750MU 1
P1 Front Left Seat Cushion 64142FA750MU 1
P1 Front Right Seat Cushion 64142FA740MU 1
Plastic Pop "Rivets" 57728AC090 1
Plastic "Screw" Rivets 794070240 1
Power Antenna 86321FA030 1
Radio DIN Pocket 66128AE000 1
Rear Bumper Cover E7710FS000 1
Rear Differential Protector B0310AS002 1
Rear Fog Lamp Switch (Eurospec Cars) 83001FC061 1
Rear Spats (Underspoiler) Full Kit With All Hardware X5771FA000 1 Kit
Rear Spat (LH Side Single Spat) 57796FA030 1
Rear Spat (RH Side Single Spat) 57796FA020 1
Rear Spat Protector Strip RH (The Rubber Trim Strip) 96054FA140 1
Rear Spat Protector Strip LH (The Rubber Trim Strip) 96054FA150 1
Rear Spat Threaded Mounting Plate 57790FA080 1 Pair
Rear Wiper Arm Assembly (Japan Spec) 86532AA000 1
Rear Wiper Arm Cover (Japan Spec) 86538GA080 1
Rear Wiper Blade Assembly (Japan Spec) 86542AA000 1
RS Bulkhead Wiring Loom (1999-2001) 81322FA100 1
RS Brake Booster (1998 Model Year) 26401FA030 1
RS Clutch Cover (1999-2001) 30210AA411 1
RS Clutch Disk (1999-2001) 30100AA690 1
RS Clutch Flywheel (1999-2001) 12342AA000 1
RS Clutch Gasket (1999-2001) 44022AA020 1
RS Clutch Radial Bearing (1999-2001) 30502AA051 1
RS Engine Hood 57220FA090 1
RS Engine Mounts RH 41022AA080 1
RS Engine Mounts LH 41022AA090 1
RS Fog Light RH 84501FA380 1
RS Fog Light LH 84501FA390 1
RS Fog Light Bracket (RH) 84927FA001 1
RS Fog Light Bracket (LH) 84927FA011 1
RS Fog Light Cover (RH 99-01) 57744FA220SJ 1
RS Fog Light Cover (LH 99-01) 57744FA230SJ 1
RS Front Brake Pads 26296FA100 1 Pair
RS Front Brake Caliper (RH) 26291FA050 1
RS Front Brake Caliper (LH) 26291FA060 1
RS Brake Caliper Pins (Need 4) 26228FA000 1
RS Brake Disc Shield (RH) 26290AC100 1
RS Brake Disc Shield (LH) 26290AC110 1
RS Front Bumper Inner Beam (00-01) 57760FA500 1
RS Front Bumper Beam (US 98 and Canada) 57760FA002 1
RS Front Bumper Vent (RH) 57744FA200 1
RS Front Bumper Vent (LH) 57744FA210 1
RS Front Bumper Skin (US 00-01) 57720FA280 1
RS Front Bumper Skin (US 98 and Canada) 57720FA160 1
RS Front Bumper Turn Signal (RH 99-01) 84441FA160 1
RS Front Bumper Turn Signal (LH 99-01) 84441FA170 1
RS Handbrake Assembly RH 26051FA140 1
RS Handbrake Assembly LH 26051FA150 1
RS Headlight (RH 99-01) 84001FA441 1
RS Headlight (LH 99-01) 84001FA451 1
RS PCV Valve 11810AA000 1
RS Rear Bumper Cover 57720FA032 1
RS Sideskirt Clip (Need 14 For New Install) 91167AA110 1
RS Sideskirt Clip (Need 6 For New Install) 91167AA000 1
RS Sideskirt Clip (Need 2 For New Install) 96058FA100 1
RS Sideskirt Front Right 96053FA000 1
RS Sideskirt Front Left 96053FA010 1
RS Sideskirt Rear Right 96053FA020 1
RS Sideskirt Rear Left 96053FA030 1
RS Sideskirt Protector Front Right (The Rubber Trim Strip) 96054FA120 1
RS Sideskirt Protector Front Left (The Rubber Trim Strip) 96054FA130 1
RS Stock Corner Lens (RH) 84401FA040 1
RS Stock Corner Lens (LH) 84401FA050 1
RS Stock Wheel (2000-2001) 28111FA270 1
Security System Upgrade (1998-2001) H7110FS201 1
Shifter: Nut 023508000 1
Shifter: Stock Shifter Bushings 35035AC030 1
Shifter: Washer/Plate 35017AA002 1
Short Throw Shifter Kit (SPT) C1010FA000 1
Sideview Mirror Glass (Right Side) 91039FC040 1
Sideview Mirror Glass (Left Side) 91039FC050 1
Single Stage Brake Booster 26402FA071 1
Single Stage Brake Booster Master Cylinder 26401AA231 1
Skidplate, Front SCI600036 1
Steel Take-Off Wheels 28111AC100TO 1
Steering Wheel Mounted Boost Gauge H5010FA032 1
STi Engine Mounts RH ST4100055110 1
STi Engine Mounts LH ST4100055120 1
STi Foglamp Cover Mounting Hardware ST5771155000 1
STi Front Strut Tower Bar (Non Carbon-Fiber) ST2050055040 1
STi Gas Cap ST4203355000 1
STi Strut Hats Front ST2031055000 1
STi Strut Hats Rear RH ST203704S000 1
STi Strut Hats Rear LH ST203704S010 1
STi Rear Differential Bushing Front ST4130055000 1
STi Rear Differential Bushing Rear ST4130044000 1 Set
STi Rear Strut Tower Bar (Sedan/Coupe) ST2050055030 1
STi Rear Strut Tower Bar (Wagon) ST2050055020 1
STi Stainless Steel Door Sills (Sedan, Front Pair Only) E1017FA003 1 Pair
STi Stainless Steel Door Sills (Sedan, Full Set) E1017FA002 4 Pieces
STi Stainless Steel Pedal Set Chrome (Manual Transmission) E1017FA002 4 Pieces
STi Tach/Speedo Cluster (Tach in Center) ST8100055230 1
STi Transmission Mounts 41022FA080 1
STi Two Pot Brake Adjuster Assembly (Need 4 For New Install) 26258AA020 1
STi Two Pot Backing Plate (LH) 26655FA030 1
STi Two Pot Brake Caliper Pin (Need 4 For New Install) 26267AA010 1
STi Two Pot Brake Caliper (RH) 26692FA000 1
STi Two Pot Brake Caliper (LH) 26692FA010 1
STi Two Pot Brake Shoe Hold Down (Need 4 For New Install) 26267AA010 1
STi Two Pot Brake Lever (RH) 26259PA000 1
STi Two Pot Brake Lever (LH) 26259PA010 1
STi Two Pot Brake Pad Clips (Need 2 For New Install) 26232AA040 1
STi Two Pot Parking Brake Shoe Disc 26298AA020 1
STi Two Pot Brake Plate (Need 2 For New Install) 26268PA000 1
STi Two Pot Brake Rotor (Need 2 For New Install) 26710FA130 1
STi Two Pot Brake Spring Adjuster (Need 2 For New Install) 26265AA071 1
STi Two Pot Brake Shoe (Need 4 For New Install) 26265AA040 1
STi Two Pot Brake Spring (Need 2 For New Install) 26267AA010 1
STi Two Pot Brake Spring Washer (Need 2 For New Install) 625303000 1
STi Gold Electra Rims ST2810079000 1
STi Strut Hat Complete Front ST2031055000 1
STi Strut Hat Complete Rear ST2032044140 1
STi Version 4 Wiring Loom 81403FA211 1
STi Version 5/6 Foglamp Cover RH 57744FA220SJ 1
STi Version 5/6 Foglamp Cover LH 57744FA230SJ 1
STi Version 6 Front Lip Spoiler 57796FA530NN 1
STi Version 5/6 Rear Bumper Cover 57720FA132 1
Subaru Parts Reference Guide (1985-2000) MSA6P0005 1
Subaru Strut Tower Brace E4010FA000 1
Swaybar Endlink Bolt And Washer 901250054 1
Swaybar Endlink Nut 902350001 1
SWRT Rally Blue Mudflaps Front ST9601055100 1 Set
SWRT Rally Blue Mudflaps Rear ST9601055110 1 Set
Tail Combination Lens (Red/Clear) RH 84201FA180 1
Tail Combination Lens (Red/Clear) LH 84201FA190 1
Timing Belt Tensioner 13033AA002 1
Toolkit (MY00) 97010AA050 1
Trunk Light 84611GA000 1
Trunk Light Striker Plate Assembly 57531FA000 1
Trunk Net F5510FS000 1
Wheel Locks T3010YS010 1 Set Of 4
WRC "SWRT" Shift Knob ST3502255000 1
WRX Brake Caliper Bracket 26225AE000 1
WRX Brake Rotor 26310AC040 1
WRX Vented Brake Duct Mud Guards (RH) 59110FA061 1
WRX Vented Brake Duct Mud Guards (LH) 59110FA061 1
WRX Vented Brake Duct Only (RH) 59110FA060 1
WRX Vented Brake Duct Only (LH) 59110FA070 1
Stuart Logan N7QYJ
slogan@mac.com
91' Legacy Turbo Sedan
98' Legacy GT Wagon
99' Impreza 2.5RS Turbo Coupe
ADVERTISEMENT
<http://rd.yahoo.com/M=210168.1566640.31 ... 1&sex=male> Click Here!
<http://us.adserver.yahoo.com/l?M=210168 ... =690532778>
Digest Number 403
