WRX shifter on ebay - CHEAP!!
Posted: Thu Mar 13, 2003 10:12 pm
by boostjunkie
For those that want the assembly for a short shift kit . . . bidding closes in about a day:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33736
Posted: Fri Mar 14, 2003 4:55 am
by -K-
I though the shift link was different on the WRX ?
Posted: Fri Mar 14, 2003 2:41 pm
by boostjunkie
That's the idea. It'll still bolt up but you can get a short shift lever that will fit this different linkage. NO SHORT SHIFTERS work for our stock linkage.
Posted: Fri Mar 14, 2003 3:15 pm
boostjunkie wrote:That's the idea. It'll still bolt up but you can get a short shift lever that will fit this different linkage. NO SHORT SHIFTERS work for our stock linkage.
The sti one does. Dave has one in his wagon.
Posted: Fri Mar 14, 2003 3:48 pm
by boostjunkie
The STi design replaces all of the components found in the WRX linkage. They are pretty much the same unit, with very minor differences in the levers. I figure if someone wanted to pick this unit up for say $40 or so, they could get a short shift lever for $80 and for around $120 have a short shift kit . . . try and find an STi assembly for that much :shock:
Posted: Fri Mar 14, 2003 4:20 pm
what do the sti units run?
Posted: Fri Mar 14, 2003 4:24 pm
by boostjunkie
Around $300.
Posted: Fri Mar 14, 2003 4:28 pm
Does the sti one have any advantages over doing the WRX shifter assembly and short shifter?
Posted: Fri Mar 14, 2003 4:51 pm
by boostjunkie
From what i hear the shift linkage really doesn't differ too much in terms of feel. Alot of people say that the stock linkage (in this case the wrx linkage) has identical parts . . . only difference being the lever, which isn't even that much different from the stocker!!
I had a kartboy shift lever in my GT and I loved it. Very short and precise throws.
Of course, my thoughts on the STi shifter are based on a lot of other people's remarks and not actual useage . . . But bang-for-the-buck, I really don't think the STi would be that much better. A couple people I know who have the STi units actually CHANGE the shift lever for a kartboy or similar :shock:
Posted: Fri Mar 14, 2003 6:34 pm
by STi_GUY
I could really use that. My shifter is really torn up. It doesnt even center itself anymore. If nobody else wants it... I got dibs :D . Thanks
Posted: Fri Mar 14, 2003 8:53 pm
All I know is the stock WRX shifter sucks.....there's way too much throw. I have shifted several ones that have the SPT short throw shifter in it, and it's better.
Probably the best shifter I've used on a subie is on my buddy's 99 RS, with a short shifter installed. Extremely crisp and tight shifts, short throws. it's great.
Posted: Fri Mar 14, 2003 9:53 pm
by boostjunkie
STi_GUY, by all means get it!! That's why I posted the link . . . I have WAAAAY too many projects going on right now to add this one.
I figure I'll just have my friend try to copy the DIY short shifter on DLCs site. He's pretty good at welding stuff:)
WRX shifter in 91 legacy turbo?
Posted: Mon May 12, 2003 5:16 am
by pjgaerlan
I have a shifter linkage also. So this will bolt up into our linkage?? I was hoping so that I could get another perrin short shifter or a WRX shift lever to make it a shorter throw. Feels like I'm shifting a VW bus
PJ
Please reply if you have any more info
Will this wRX shifter bolt in or is the legacy linkage diff?
Posted: Tue May 13, 2003 2:26 am
by k2snow1
Anybody? Bueller? Bueller?
I heard that the STI short shifter will work but the joint that bolts up to the linkage and the tranny is different.
Please reply.
PJ
Posted: Tue May 13, 2003 1:45 pm
by boostjunkie
DLC should be able to answer this question as I got the idea from his site.
Posted: Thu Sep 09, 2004 7:35 am
by Paisan
Does anyone know if the wrx short shifter from kartboy definitively fits the legacy turbo 90-94???
-mike
Posted: Thu Sep 09, 2004 1:38 pm
by legacy92ej22t
