Disconnect From Engine?
joe002
Post by joe002 »
I’m trying to disconnect my exhaust pipes from my EJ-22 Engine. I removed the three bolts that bolt the pipe to the engine, but the pipe doesn’t seem to want to move. Do I have to go downstream and remove more pipes in order to remove it? Thanks.
Yes,
You will also need to remove the bolts holding the exhaust manifold onto the rest of the exhaust to get the manifold out.
