engine temp sensor?
Locked
firetire@hotmail.com
engine temp sensor?
Post by firetire@hotmail.com »
Hello,
Some one has the engine temp sensor diagnostic procedure? My car , a
legacy turbo when start with the engine at midle warm, the idle is
erratic but when it is cold or get the operating temperature is fully
OK, I don´t know what could be, I am thinking check the temperature
sensor but I have not the procedure, please help me.
FREE COLLEGE MONEY
CLICK HERE to search
600,000 scholarships!
http://us.click.yahoo.com/Pv4pGD/4m7CAA ... /XoTolB/TM
Rod
engine temp sensor?
Post by Rod »
have you done a ecu systems check?
see http://www.mrtrally.com.au/performance/howresetecu.htm
or
http://www.xmission.com/~dac/library/codes.htm
cheers, Rod in OZ
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Tuesday, October 16, 2001 9:41 PM
Subject: [BC-BFLegacyWorks] engine temp sensor?
> Hello,
engine temp sensor?
Rod,
I don´t know if i am right, but the ecu system check is in case that
the lamp goes on anytime, in my car never lights on, at least when
the engine is running, I think that some sensor is sending a wrong
reading when the engine is warming up and the ecu don´t detect this
like a fail.
Regards,
Christian
> or
> cheers, Rod in OZ
> From: <firetire@h...>
> To: <BC-BFLegacyWorks@y...>
> > Hello,
car , a
fully
temperature
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
FREE COLLEGE MONEY
Rod
engine temp sensor?
Post by Rod »
Christian,
even if the light does not come on it will store any probable faults,
intermitent faults etc that have occured. This may give you an indication on
where the problem may lay.
Check it and see what codes you turn up. If there are a few fault codes
displayed, due to the fact the ecu's memory hasn't been cleared for a long
period of time, clear its memory, wait for the fault to happen again and
then re-check it.
regards, Rod...in OZ
Sent: Wednesday, October 17, 2001 8:30 AM
Subject: [BC-BFLegacyWorks] Re: engine temp sensor?
> Rod,
> like a fail.
> Regards,
> Christian
> > or
> > cheers, Rod in OZ
> > > Hello,
> car , a
> fully
> temperature
FREE COLLEGE MONEY
Locked
