Lightened Flywheel?
-K-
Lightened Flywheel?
Post by -K- »
I just pulled my tranny to change the clutch and the flywheel is shot. It's cracked to hell and some cracks run almost 1/4 in deep. So I need a new one and want to know if any one makes a lightened flywheel for my car. Or if a WRX flywheel works. I can find one for a WRX but would I need the clutch for it also?
02 WRX Sedan, 5mt
93 Sport Sedan, 5mt
kelley
Vendor
Vendor
Post by kelley »
sti makes both fot the legacy turbo. you can get prices at www.rallispec.com
ej22t
Post by ej22t »
I has a light weight flywheele just for sell, it lighted by the stock flywheele by 10 lb less the total weight of the flywheele now is 16lb only.
The flywheele are lighted and balance , the reason I sell it because my tranny has problem so I have to sell it for some money to fix the tranny problem!
If you needs pics , let me know.
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
Sir Yach-o
Post by Sir Yach-o »
Is it true that you're not supposed to use both a lightened flywheel and lightened pulley at the same time?
I heard this somewhere, but can't remember the basis behind it.
-mike
I'm saving up for my Yugo.
DLC
Post by DLC »
I've had a lightweight flywheel (Exedy) and a UOR pulley on since February with no ill effects, but that's not really a long time.
I'd like to hear opinions on whether it's bad or not, but the whole subject of balancing in the engine has been covered innumberable times before.
Legacy Central
JasonGrahn
Post by JasonGrahn »
Primitive Enterprises makes a really nice lightened flywheel. it's about 11lbs lighter then stock. http://www.get-primitive.com
It's not TOO light to make the car undrivable, but it's light enough to add more of a sporty feel to the car.
-Jason
-Jason Grahn
DLC
Post by DLC »
Lex got one from him, with an ACT clutch, for his 5MT conversion. When i drove it early this year, it felt a lot like my Exedy/STi setup. Any quality flywheel that's between 12-14lbs makes a world of difference in 1st gear and when rev-matching.
Legacy Central
Brat4by4
Stratified
Post by Brat4by4 »
What is too light for a flywheel? I can get a fidanza flywheel for $299... but it only weighs 9.6 lbs! http://www.jscspeed.com/wrx/clutch.htm - I wanted to shoot for 12-14lbs because that is how light STi makes them. Will I regret getting this light of a flywheel? The car is going to be a daily-driver.
Brat4by4
Stratified
Post by Brat4by4 »
Found another site that says their Fidanza flywheel weighs 11 lbs. The man at JSC said he only saw one listed for 9.6 lbs... getting confused... :evil: http://www.ptuning.com/html/Item-Desc.c ... reza%20WRX
These prices are pretty good and I would get them... yet I don't want my car stalling everytime I try to maneuver in a parking lot.
DLC
Post by DLC »
I dig my Exedy, and it's between 12-14lbs. If it's 9...that might be bad.
Mine's very driveable, but i also have a STI clutch and pressure plate with STI engine and trans mounts, so there's no slack in the drivetrain to worry about. Streetlight launches are no problem, and i've only stalled it 3-4 times in the last year.
Legacy Central
