Oil pan gasket?
Aaron's ej22t
Oil pan gasket?
Post by Aaron's ej22t »
anyone changed it?
you have to remove the crossmember, right ?
92 Legacy Turbo \ 5MT \ Silver
scoobiedoo22
Post by scoobiedoo22 »
I did this when I had my motor out of the car, no gasket though, just high temp, oil resistant, silicone sealent. To do it in the car, I am sure you do have to remove the crossbar, I know they cover it in the Hayne's manual if you have one. John
1991 Legacy SS 5-Speed
1999 Impreza 2.5RS Coupe
petridish38
Post by petridish38 »
I'm about to do my oil pan gasket.... Does anyone who has done this know if there is any way to do this without using an engine hoist?
Andrew
209,000 miles!
2002 Impreza WRX Sport Wagon
THAWA
Post by THAWA »
petridish38
Alright.... I figured out how to raise then engine without a hoist... I used a jack and a block of wood to jack up the transmission. Then, I put a block of wood underneath each engine mount and lowered the jack but left it half supporting the transmission to be safe.
Here is a pic
Although it was tight, I had enough room to fit my average sized fingers in the back with a U-joint socket
Everything is put back together now...I'm just waiting 24 hours for the gasket to dry, after which I will start the car and hope that it doesn't leak!
EDIT: She's back up and running.... but I will need at least a week to see if it leaks...I hope not
Andrew
209,000 miles!
shemoves
Post by shemoves »
Was reading through this and thought I'd post. It is possible...although a pain in the nack...to remove the oil pan without raising the engine. A small swivel joint and long extension (if not two) are needed to get to those pesky rear bolts. You can use the small holes in the cross member to see what you are doing and long 'L' shaped needle nose pliers to help positioning.
