Moderators: Helpinators , Moderators
Posts: 12517 Joined: Sun Nov 03, 2002 2:13 am
Post
by vrg3 » Mon Mar 24, 2003 5:20 am
Josh said in another post:
Legacy777 wrote: Motor mounts are motor mounts......ones for the legacy will fit in the impreza and vice-versa.......
Is that true between turbo and N/A engines? I know the crossmembers are different, which is why I ask.
For example, could I use a set of mounts meant for a GC Impreza 2.5RS on my BC turbo? Or from a GD 2.5RS, for that matter?
Posts: 27932 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Mon Mar 24, 2003 2:52 pm
Like I said.....everything I have read and heard from vendors is there is only one part number for motor mounts.
Give Adam @ Z1 a call or email and ask him. I know he sells them....so he should be able to look them up and tell you for sure.
DLC
Posts: 2776 Joined: Tue Oct 15, 2002 1:58 am
Post
by DLC » Tue Mar 25, 2003 4:01 am
The crossmembers are different, but that doesn't affect where the engine mounts are, just where the exhaust is routed.
Legacy Central
2001 Legacy Outback Wagon | 2005 OB XT LTD | 1997 Legacy Outback Limited | 1998 Legacy L Wagon |
2000 GT Limited | 93 Legacy Touring Wagon 5MT | 90 Legacy L+
mikec
Posts: 893 Joined: Tue Jan 21, 2003 8:27 pm
Post
by mikec » Tue Mar 25, 2003 4:28 am
Just to repeatedly kick a dead horse...
Mounts off a 2001 RS would work, right? Someone up here in Toronto is looking to sell his, and I thought I might investigate further. Of course, if they're not going to fit, I'll look at other stuff I need more. I can't afford to buy them and then find they don't work. Of course, right now, I can't really afford to buy them at all
, but I thought I'd inquire...
DLC
Post
by DLC » Tue Mar 25, 2003 9:48 pm
They should fit just fine.
Legacy Central
mikec
Post
by mikec » Tue Mar 25, 2003 9:49 pm
Thanks! Now to see about the price....
