Supercharger kit coming soon
ciper
Post by ciper »
I post this because someone mentioned they had a first gen legacy as a test vehicle 8)
Read these:
http://forums.nasioc.com/forums/showthr ... did=334586
http://forums.nasioc.com/forums/showthr ... did=334152
http://www.subaruwedding.com/SCThread.htm
Basically for 3-4k you get a kit that installs in 2-3 hours. Still not final but the prototype is running great.
that looks very simple and very basic, but looks like it'll do the job well.
KISS method baby :)
Brat4by4
Stratified
Post by Brat4by4 »
No intercooler? hmmmmmm.... dat can't be good
eastbaysubaru
Post by eastbaysubaru »
Hey, mine's not intercooled either :( :lol:
-Brian
'04 PSM FXT
Aaron's ej22t
Post by Aaron's ej22t »
it is only running 6psi, so an IC is not really necessary. besides, our cars run 8.7psi and they don't have intercoolers. though, i would still use one. you could add a tmic ic very easily to that kit, change out the pulley and run 10psi, then it would haul! :o
92 Legacy Turbo \ 5MT \ Silver
ciper
Post by ciper »
They said a stage two unit would be available with intercooler. Air to water type. Look at the design though, it would be easy to add one.
STi_GUY
Post by STi_GUY »
This is definately worth investigating for us NA guys. Depending on price, this could be an alterative to an engine swap. Supercharger drive characteristics are way different than that of a turbo. Could make a VERY unique subie out of it. Stage two sounds fun. :twisted:
Cody
1994 Legacy Ti Wagon (Estate)
2.4L of N/A fury :)
Awesome vendor: http://home.att.net/~teaguesauto/index.htm
DLC
Post by DLC »
If someone was willing, this could be used if someone wanted to convert from a turbo. Due to the lower compression ratio of the turbos, you could run more boost without worrying about that intercooler, and even more with.
Regardless, that's pretty neato.
Legacy Central
STi_GUY
Post by STi_GUY »
Ciper,
When could someone get a hold of one of these blowers. I'd love to get one this summer. Will the stage 2 be ready by then. And who is making the kit? I'm sooooo ready to get some forced induction under my hood.
Cody
2.4L of N/A fury :)
mile hi
Post by mile hi »
Word is that they were running 7lbs boost at low altitude and I do mean were the engine blew. 7lbs on a n/a engine is asking for trouble. The kit that is being built here in CO probably is a bit nicer it is being installed now.
AL(CO)
al@iwtu.net
ciper
Post by ciper »
From what I have read stage one isnt ready for production yet. Stage two shouldnt really be too different, just intake piping and intercooler mounting.
Look on nasioc for a user named Templar. The kit is made by DNT Performance.
Id guess the hardest part for them is making a cheap mount bracket in any type of qauntity (wouldnt that have to come from a big block of alluminum then machined down?)
STi_GUY
Post by STi_GUY »
Thanks, I guess I'll just have to wait and see. Do you think they will have diff size pulleys available for different levels of boost. Or is it possible to have a boost controller? Manual or electric? I'm just really interested in this kit. Can you blame me? :D
Cody
2.4L of N/A fury :)
