does anyone know the measurements for testing the thermostat for a 91 sport sedan (auto)
_____
Do You Yahoo!?
Send your FREE holiday greetings online at Yahoo! Greetings <http://rd.yahoo.com/mail_us/tag/?http:/ ... yahoo.com/> .
Thermostat
Thermostat
What do you mean? The temp it's supposed to open? If you're in question of it being bad or not. Just replace it. It's like 6 bucks. I must tell you too, buy the OEM one from the dealer. It's pretty much the same price, and will save you headaches. The aftermarket ones you get at the auto parts stores are smaller, and will close when you rev the engine, and cause you hell. So just get the OEM one and a gallon of antifreeze, do a flush and 50/50 mix, and you're good to go.
Josh Colombo
<mailto:Josh@surrealmirage.com> Josh@surrealmirage.com **NEW**
of beats and rhythm" - ME
-----Original Message-----
Sent: Wednesday, December 05, 2001 6:52 PM
Subject: [BC-BFLegacyWorks] Thermostat
_____
Do You Yahoo!?
Send your FREE holiday greetings online at Yahoo! <http://rd.yahoo.com/mail_us/tag/?http:/ ... yahoo.com/> Greetings.
ADVERTISEMENT
<http://rd.yahoo.com/M=178320.1681224.32 ... /yahoo-75f>
<http://us.adserver.yahoo.com/l?M=178320 ... =236168294>
Josh Colombo
_____
Do You Yahoo!?
ADVERTISEMENT
Thermostat
> Do You Yahoo!?
> Send your FREE holiday greetings online at Yahoo! Greetings.
If you are really keen on testing your thermostat just throw it in a
pot of boiling water. If it doesn't open its no good, if it opens
then its fine. Are you noticing something that is pointing to a
faulty thermostat or are you simply very preventive maintenance
minded. I just changed the thermo on my 535i because it was stuck
open. Now I have heat!
Sean L
Promise to Quit
Nicotrol will help
http://us.click.yahoo.com/5vN8tD/AqSDAA ... /XoTolB/TM
> Do You Yahoo!?
Sean L
Promise to Quit
Nicotrol will help
Thermostat
I'm getting 13mpg... checked the ecu...it gave the code for thermo and 02. Changed the 02 but its still giving those code after reset. I hope its the thermo... nice $10 fix!
> Do You Yahoo!?
Sean L
Your use of Yahoo! Groups is subject to Send your FREE holiday greetings online at Yahoo! Greetings <http://rd.yahoo.com/mail_us/tag/?http:/ ... yahoo.com/> .
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=178320 ... =647880310>
> Do You Yahoo!?
Sean L
ADVERTISEMENT
Thermostat
Don't even bother, the part is very cheap - which is dependant on your
defininition of the word. But I consider myself only slightly less
conservative than Scroodge himself. I can dig out the info if you have to
know, but honestly it's a very inexpensive part.
=Sambo
Sent: Friday, December 07, 2001 12:11 PM
Subject: [BC-BFLegacyWorks] Re: Thermostat
> Do You Yahoo!?
Sean L
Promise to Quit
Nicotrol will help
=Sambo
> Do You Yahoo!?
Sean L
Promise to Quit
Nicotrol will help
