'deck'. I've been told by my mechanic friend this as
well as a few others. I could be WAYYY off though.
I think the 2.2L turbo is probably the best turbo
engine that Subaru has imported. It's closed deck,
which AFAIK acts like a heat sink so you can increase
boost/internal temps and still be super reliable.
Someone correct me if I'm way off please. The H6 is a
much heavier engine, which adds a bunch of weight to
an area that really doesn't need any more.
I also had a few questions that you guys could
probably answer.
-What does the battery light on the dash indicate?
I'm assuming something about the battery and the power
level. I'll be reading my Haynes manual today, so I
may answer it myself, but I always value the opinions
on here much more.
-Before we do this exhaust GB, I want to do some tests
on my engine to make sure it's operating properly.
What test should I do or have done to check this?
Thanks a lot.
-Brian
--- Josh Colombo <josh@surrealmirage.com> wrote:
> You have an open block. I think there were a very
> few 89-90 Legacies that had closed block. Then
> after that, they went open block on them...or at
> least that's what I have told.
> The new H6 in the Outbacks will most likely fit in
> the early gen legacies. However the electronics are
> goin to be quite different....plus the fact that it
> being a brand new engine, finding anything used is
> going to be very difficult, so for a swap like
> that....it would be quite spendy.
> The main thing the new H6 is going to have over the
> turbo 2.0 is more lower end torque. I personally
> would want the 2.0 turbo over the 6. I just like
> turbo's better, and more hp can be gained easier
> with the turbo engines then a N/A engine.
> Josh
> Josh Colombo
> Josh@surrealmirage.com
> <mailto:Josh@surrealmirage.com> **NEW**
> "Life, an ever-changing melody
> of beats and rhythm" - ME
> -----Original Message-----
> From: f13ndus [mailto:f13ndus@yahoo.com]
> Sent: Saturday, December 22, 2001 121 PM
> To: BC-BFLegacyWorks@yahoogroups.com
> Subject: [BC-BFLegacyWorks] a few questions I
> thought of...
> Hey all,
> these questions just popped into my head as I was
> sitting here...
> 1.) Is my 1994 Legacy L Sedan closed block or open
> block?
> 2.) Does anyone know of anyone selling a relatively
> cheap Turbo
> sedan, because I'd REALLY like to get one and be
> able to give this
> car back to my parents (it was theirs first) or sell
> it...
> 3.) The new outbacks have a 6 cylinder 3.0L engine,
> right? How does
> that compare to our 2.0/2.2L engines? Is it just
> like a smaller SVX
> engine? And could one fit in a 90-94 Legacy?
> Thanks,
> Iain
__________________________________________________
Do You Yahoo!?
Send your FREE holiday greetings online!
http://greetings.yahoo.com
Send FREE Holiday eCards from Yahoo! Greetings.
http://us.click.yahoo.com/IgTaHA/ZQdDAA ... /XoTolB/TM
