a few questions I thought of..
Posted: Sat Dec 22, 2001 2:25 pm
by Brian White
I'm not too sure, but I think it's referred to as open
'deck'. I've been told by my mechanic friend this as
well as a few others. I could be WAYYY off though.
I think the 2.2L turbo is probably the best turbo
engine that Subaru has imported. It's closed deck,
which AFAIK acts like a heat sink so you can increase
boost/internal temps and still be super reliable.
Someone correct me if I'm way off please. The H6 is a
much heavier engine, which adds a bunch of weight to
an area that really doesn't need any more.
I also had a few questions that you guys could
probably answer.
-What does the battery light on the dash indicate?
I'm assuming something about the battery and the power
level. I'll be reading my Haynes manual today, so I
may answer it myself, but I always value the opinions
on here much more.
-Before we do this exhaust GB, I want to do some tests
on my engine to make sure it's operating properly.
What test should I do or have done to check this?
Thanks a lot.
-Brian
--- Josh Colombo <josh@surrealmirage.com> wrote:
> You have an open block. I think there were a very
> few 89-90 Legacies that had closed block. Then
> after that, they went open block on them...or at
> least that's what I have told.
> The new H6 in the Outbacks will most likely fit in
> the early gen legacies. However the electronics are
> goin to be quite different....plus the fact that it
> being a brand new engine, finding anything used is
> going to be very difficult, so for a swap like
> that....it would be quite spendy.
> The main thing the new H6 is going to have over the
> turbo 2.0 is more lower end torque. I personally
> would want the 2.0 turbo over the 6. I just like
> turbo's better, and more hp can be gained easier
> with the turbo engines then a N/A engine.
> Josh
> Josh Colombo
> Josh@surrealmirage.com
> <mailto:Josh@surrealmirage.com> **NEW**
> "Life, an ever-changing melody
> of beats and rhythm" - ME
> -----Original Message-----
> From: f13ndus [mailto:f13ndus@yahoo.com]
> Sent: Saturday, December 22, 2001 121 PM
> To: BC-BFLegacyWorks@yahoogroups.com
> Subject: [BC-BFLegacyWorks] a few questions I
> thought of...
> Hey all,
> these questions just popped into my head as I was
> sitting here...
> 1.) Is my 1994 Legacy L Sedan closed block or open
> block?
> 2.) Does anyone know of anyone selling a relatively
> cheap Turbo
> sedan, because I'd REALLY like to get one and be
> able to give this
> car back to my parents (it was theirs first) or sell
> it...
> 3.) The new outbacks have a 6 cylinder 3.0L engine,
> right? How does
> that compare to our 2.0/2.2L engines? Is it just
> like a smaller SVX
> engine? And could one fit in a 90-94 Legacy? ;)
> Thanks,
> Iain
Do You Yahoo!?
Send your FREE holiday greetings online!
http://greetings.yahoo.com
Send FREE Holiday eCards from Yahoo! Greetings.
http://us.click.yahoo.com/IgTaHA/ZQdDAA ... /XoTolB/TM
Posted: Sat Dec 22, 2001 2:45 pm
by Josh Colombo
couple comments.
The closed deck design is mainly beneficial because the strength of it. You have more material around the cylinder which will handle more forces and higher boost. The open deck design is ALOT cheaper to produce when they cast the block. The closed deck blocks require more extensive casting setup and such.
The new H6 really isn't much bigger then the H4. I think it's only about an inch or so longer....may be a little heavier...but not by much I think.
The battery light is an indication of a malfunction in the charging system. I would suspect either your alternator or battery is on the fritz, and needs replacing....or possibly both.
Josh Colombo
Josh@surrealmirage.com <mailto:Josh@surrealmirage.com> **NEW**
Sent: Saturday, December 22, 2001 1:20 PM
Subject: [BC-BFLegacyWorks] a few questions I thought of..
probably answer.
on here much more.
Thanks a lot.
-Brian
> Josh
> Josh Colombo
> thought of...
> Hey all,
> sitting here...
> block?
> cheap Turbo
> able to give this
> it...
> right? How does
> like a smaller SVX
> Thanks,
> Iain
Do You Yahoo!?
