Hi,
What's the best procedure to detach the clips without breaking in
them in order to remove the front radiator grille?
Instructions on how to remove the grille
Josh Colombo
Take a needle nose pliers and gently squeeze the clips....you'll be able to slide the grill off slowly...clip by clip.
