Ben's engine pistons and exhaust
Posted: Thu Jan 10, 2002 3:42 pm
Hi Ben,
OEM EJ22T pistons are factory turbo pistons. I think you should have no problems at 15 psi since overseas I think 12 psi is stock boost, and guys go to 15 and more quite regularly.
I also forgot to mention JE Pistons. Probably the most popular Japanese subcompact aftermarket vendor right now. Check them at http://www.jepistons.com/
The EJ20T and EJ22T block have the same external dimensions, but the exhaust manifold comes off the heads which *MIGHT* have slightly different port spacing or bolt patterns. It is another one of those "MAYBES" that could cause one more bit of grief for a swap, but at least not a showstopper. Somebody out there with first hand experience please help on this one.
