The Wrath of Zeus
Brat4by4
Stratified
The Wrath of Zeus
Post by Brat4by4 »
Here is an interesting problem. My car has recently decided to start witholding a large capacity of voltage. In other words, when I get out... it shocks the &$*%() out of me. When it is dark outside, I can SEE it ARC! In fact, I didn't really think about it until it started arcing to my elbow through clothing when I was at least 6" away from the car.
It actually shocked me through my winter coat when I was getting out of the car. Since my little keyless entry holder broke, I use the key. I often see it arc (again) to the key. I was just wondering if anyone knew what the heck causes this to happen, plus I'm sure it can't be that good for the powerlocks and keyless entry when it arcs through the lock. It happens after I've driven for a little bit, even as little as 2 miles.
ciper
Post by ciper »
What brand/type of tires do you use?
The POS buick I drove in memphis did this to me all the time.
Your tires are building up a static charge. It seems to be the most prevalant with harder compound tires.
You can do what some big rigs do as well as fuel trucks. They have a rubber strip that drags along the road....which is mounted to the chassis......this will help discharge any built up static electricity.
Brat4by4
Stratified
Post by Brat4by4 »
They are the stock tires off the WRX. Potenza SE-90 or something like that. I wouldn't quite consider them pieces of crap. And this is something that started recently, maybe it's the humidity. I don't know, but weird nonetheless. It actually discharged today when I touched the metal on the inside door handle. I thought about the rubber strips, but I don't know how easy that would be to pull off.
ciper
Post by ciper »
I live in an area that has the highest population of asians in the US. That said I see SO MANY cars with grounding straps. Not sure where you could purchase them near you but they mount near the rear bumper. They are rubber on the outside with two metal braided strips inside. Wind causes them to come away from the road, when you slow they come down and touch.
BTW the tires are re-92 and realize they are LARGER THAN STOCK, meaning your car is now slow.
The rubber would probably be high in carbon, like the little pads under buttons on your TV remote.
You could replace your mud flaps with them, maybe, as long as they don't get under the wheels when you move backwards or when it's windy...
IggDawg
Post by IggDawg »
It's got more to do with shoes than tires. when you move around in your seat, you build up a static charge. normally this discharges slowly though your ass and shoes. It does have to do with tires as well, since the car will bleed off static charges thorugh them. but if you have recently started wearing different shoes, that can be causing it. try driving barefoot or in just socks for one day and see if it still happens. also, try not putting on your coat till you get outa the car. rustling around in your jacket can build up an excess charge.
IggDawg is cool.
-IggDawg
1994 Barcelona Red SVX LSi.
1990 CRX Si (for sale)
Post by entirelyturbo »
Even here in relatively warm FL a 50-degree snap sends my hair straight on end after getting out of any car that has traveled at 50mph or more...
*Formerly DerFahrer*
