where's the peak power?
Locked
f13ndus
Post by f13ndus »
I've got a 94 legacy with the EJ22 N/A that I've mentioned a few
times... what RPM is the peak power at? In other words, where should
I shift for the most power?
legacycentral
Post by legacycentral »
The 93 specs are:
130hp @ 5,400RPM
137 lb/ft @ 4,400
Rod Grosvenor
Post by Rod Grosvenor »
Iain-before I turbo`d my NA engine, I found that with a K&N panel filter, Borla headers, 480v RS coil pack, NGK wires & an Unorthodox pulley that between 5500 & 5800 rpm was a good shift point range. This is @ 5,000 ft. & with a predominantly dry climate. At sea level & with denser, cooler air, you probably could pull power to 6000. Reving past your power point is excess wear & tear + poorer mileage. My .03 cents---ROD (AZ.)
Doug Hancock
Post by Doug Hancock »
is it true that from 94 onwards had less power but more torque.
Wilson, Tim
Post by Wilson, Tim »
what are the specs for 93 twin turbo ej20 engine?
milehial2000
Post by milehial2000 »
The '94 Legacy was rated at 130hp at 5400 rpm 137 lb ft torque and the
'96 Legacy was rated at 135 hp at 5400rpm 140 lb ft torque this was
probably due to a .2 point increase in compression ratio, the way
that they wanted to test them or the conditions that day but most
likely the computer came up with these numbers. The peak power depends
on several factors to numerous to mention here including any
modifications done, fuel, temperature, ect the only way to be sure
would be a good engine dyno.
Doug Hancock
bloody quick
Doug Hancock
Well a 92 NA 2.2 is 133hp so yes they have less power than a 94.
Josh Colombo
Post by Josh Colombo »
It's possible.....I think my 90 is rated at 135 hp....I'm not positive about that....it could be 130 hp
f13ndus
Post by f13ndus »
Oh yes, I've had the privelege of driving in one... bloody quick is
right!
Wilson, Tim
guy's i was hoping for a hp rating not "bloody quick" but thanks
f13ndus
Post by f13ndus »
I know you were, I've just got no idea, sorry... :(
Wilson, Tim
sweet as
John Gillon
Post by John Gillon »
Depending on the exact model and transmission... about 160kw / 220bhp for the "standard", manual trans. About 5kw less for auto trans, and 15kw more for a "GT-B spec" manual trans.
Wilson, Tim
thanks =)
milehial2000
OK I have gone through a stack of Dyno charts on the EJ engine with
various performance items. It appears that the peak is very
consistant at 5700rpm on almost all runs. This was done on a model
248C dynamometer at 86f 24.66 in. hg. 5280 ft CF=1.24 I think the
published figures are computer figures probably found during design.
AL(CO)
Locked
