Does Delta make performance camshafts for the EJ22T turbo?
By the way, about twelve years ago I rebuilt my 83 Mazda 626 and had Delta Camshafts of Tacoma regrind my cam and rocker arms.
When I installed them, the car ran very poorly then catastrophically puked, well before it ever warmed up.. A rocker arm snapped and tore a hole in the head. I had a machinist check it out and he determined that the rocker arms had all been mis-chucked. Delta freely acknowledged that they mischucked the rocker arms, but insisted that their responsibility ended at replacing the torn up cam and the rocker arms that they ruined. I was stuck with a freshly rebuilt engine that was full of metal particles from all the abrading that happened before the rocker arm snapped. I had to throw in a wrecking yard engine. Delta's sloppy workmanship and their refusal to accept responsibility for it cost me an entire engine.
Good luck if you use Delta Camshafts, you'll need it.
Delta Camshafts
