New thread for water/air intercooler info!!
Locked
stu_j_ure
Post by stu_j_ure »
Thanks for that!
is this what you mean for the The water expansion tank :
http://www.mrtrally.com.au/performance/photo/mrt264.jpg
Mark Ward_
Post by Mark Ward_ »
You will notice this is on the front of the motor, repalces the EJ20T
coolant tank...
Mark
stu_j_ure
Post by stu_j_ure »
oh you mean a larger intercooler radiator like this??
http://www.mrtrally.com.au/performance/photo/mrt083.jpg
I am considering doing this along with a high flow water pump!
Sounds like it gets some good results!
milehial2000
Post by milehial2000 »
Thats the tank, on the EJ22t it is mounted behind the manifold where
the heat makes it weak and it is in the way so it gets broken.
Locked
