best bang for the buck in modifying existing heads
Locked
ssspoon@aol.com
Post by ssspoon@aol.com »
Bill Robinson has come down to earth from ULTIMATE Formula One heads to something less costly than insane.
We still really need to know the objectives because they make a diff in what to do and what to spend.
I think maybe WRX heads are at the top of the food chain for starters, but would require some other changes too.
However, whatever you start with, I think the choices are going to be very similar about what to do...for the street.
My first choice is a good knowledgeable, skillful porting job.
The rough casting leaves a lot to be desired in the areas of port contour for optimum flow.
The polishing is just an extension of porting, which is no biggie, but the experience to know what to do, and what not to do, in reshaping the ports is valuable and uncommon. There's more than just porting that can be done to the heads. Metal in the area of valve seats and guides can be removed and combustion chambers can be reshaped. Properly done, head porting will provide an increase in torque and power throughout the entire engine operating range.
The legendary 22B uses the same block as the EJ22T. It makes the same horsepower and torque as the other hot Japan Domestic Market Subaru engines, but it leaps away from three times more expensive Porches and whatnot. Because the torque and horsepower peak at about three rpm and stay there all the way up to about 8500. It has what is described as a LOT of area under the power curve.
Cost to rework heads - $1200 to $2500 - power increase: 15% - 25%
Notice it costs about twice as much to realize 2/3 or 67% more gain
Working with the valve train to reduce reciprocating mass and friction, while at the same time increasing size, will enable even better volumetric efficiency to aid in the above gains and also permit higher rpm's for an increase at the top end of the power band. You could also just do a competition valve and valve seat regrind with the fancy valvetrain components, and not the heads for an economical increase.
Cost for new valvetrain components mild to wild - greatly dependent on how exotic you go with materials and components is like doing heads
You can go crazy not only with valve size changes, but also with lifters, springs, keepers, nuts, and associated hardware.
So valvetrain mods can go from almost nothing to right up there with the fairly expensive headwork
Mild to wild valve train mods - $200 to $2500 for an increase of 5% to 10%
Why spend at the top end of that range for only a 5% to 10% increase? Because the 5% to 10% increase would result from the lower mass, friction, and larger valve openings with no other modifications. But usually somebody spending the bucks here is doing it because of the desire to take advantage of some wild cam grind to realize an overall increase much greater than the 10%.
Careful selection of a cam profile can be accomplished to provide more torque down low in the operating range for greater acceleration at lower engine speeds, or more high end power, for greater top speed, or sometimes even, a little of both. And the thing is, the fancy valve shit, and the cams, are kind of married to each other. Other than increasing the size of the valves, the rest of that fancy valvetrain money is not too well spent performancewise without a cam to take advantage of the lower valvetrain mass. So better breathing goes with bigger valve holes, but also lifting the valve higher (lift), keeping it open longer (duration), and ramp rate (acceleration and speed of opening and closing), all contribute to greater volumetric efficiency.
Given a choice, most people go with a different cam before a valvetrain mod, because it's usually less expensive, yields about the same amount of power increase, and can be tailored to increase the power where desired on the rpm band. Also valve size increase with modern 4 valve heads often limited by the neighboring valves, so you really have to spend the bucks to get the bang out of a valvetrain mod only.
Cost for cams is pretty standard per stick depending where you shop -
$500 - $1000 for custom stuff, half that for comp bump sticks off the shelf.
Increase in power: 10% - 15% with stock valves, 15% - 20% with a top of the line valvetrain
So you can get some appreciable increases for a few hundred, or drop somewhere in the hood of 3 to 4 large, depending on where you shop, and pick up a 35 to 40 percent (it's not usually linearly additive) increase in peak power just by optimizing volumetric efficiency, without increasing compression or boost. This assumes your induction system does not choke off your gains upstream or your exhaust does not smother it downstream. Once you get started, it can be hard to stop. That's why they ask how fast do you want to go? They're really asking how much do you want to spend? For me, aside from increasing boost, which eventually leads to temperature associated problems, somewhere in the range of $2000 to $2500 in getting the cylinder head ported with a more aggressive cam profile that enhances low end torque even further is probably my limit. Limits are like armpits, most everybody has one. What's your limit Bill?
Larry Witherspoon
4260 W 182nd St.
Torrance (Los Angeles), CA 90504
day/office phone 562-982-7720
larry.d.witherspoon@boeing.com
ssspoon@aol.com
<http://rd.yahoo.com/M=153641.1824646.33 ... k=22800125> []
_____
<http://us.adserver.yahoo.com/l?M=153641 ... =289868129>
milehial2000
Post by milehial2000 »
Does anyone know what the valve setup is on the '96-'98 EJ20tt engine?
also what is the rev limiter set at? And is this head and it's valve
mechanism the same as the US Spec WRX?
to
in what
starters, but
be very
contour for
> optimum flow.
but the
ports is
done to
removed and
will
> operating range.
same
engines,
whatnot.
there all
under
> the power curve.
friction, while
for an
on how
lifters,
the
to 10%
increase?
friction,
somebody
advantage
than the
> 10%.
more torque
engine
even, a
cams, are
the
spent
valvetrain mass.
the valve
(acceleration
volumetric
> efficiency.
valvetrain mod,
power
the rpm
limited by
the bang
the shelf.
top of the
> line valvetrain
and pick
in peak
choke off
Once you
do you
For me,
associated
cylinder
torque
everybody
> Larry Witherspoon
> 4260 W 182nd St.
> larry.d.witherspoon@b...
> ssspoon@a...
Access Your PC from Anywhere
It's Easy. It's Fast. - Free Download
http://us.click.yahoo.com/lmECdA/6XkDAA ... /XoTolB/TM
John Gillon
Post by John Gillon »
For the 205kW manual trans version...
- solid lifter buckets with over-bucket shims
- rev limit is 7500rpm
- from late-96 the EJ20TT adopted the WRX3 style head which are solid
lifter, but various WRX versions are under-bucket shims... not sure about
the US version
John
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Thursday, January 24, 2002 2:49 PM
Subject: [BC-BFLegacyWorks] Re: best bang for the buck in modifying existing
heads
> to
> in what
> starters, but
> be very
> contour for
> > optimum flow.
> but the
> ports is
> done to
> removed and
> will
> > operating range.
> same
> engines,
> whatnot.
> there all
> under
> > the power curve.
> friction, while
> for an
> on how
> lifters,
> the
> to 10%
> increase?
> friction,
> somebody
> advantage
> than the
> > 10%.
> more torque
> engine
> even, a
> cams, are
> the
> spent
> valvetrain mass.
> the valve
> (acceleration
> volumetric
> > efficiency.
> valvetrain mod,
> power
> the rpm
> limited by
> the bang
> the shelf.
> top of the
> > line valvetrain
> and pick
> in peak
> choke off
> Once you
> do you
> For me,
> associated
> cylinder
> torque
> everybody
> > Larry Witherspoon
> > 4260 W 182nd St.
> > ssspoon@a...
It's Easy. It's Fun. - Free Download.
http://us.click.yahoo.com/kmECdA/7XkDAA ... /XoTolB/TM
milehial2000
I am assuming that this is a closed deck engine right ? I would like
to install these on a EJ22t that is closed deck. I know that the US
Spec WRX heads will work.
AL(CO)
solid
about
> the US version
> John
> From: "milehial2000" <acroxford@h...>
> To: <BC-BFLegacyWorks@y...>
existing
> heads
engine?
valve
heads
> > to
diff
> > in what
> > starters, but
to
> > be very
port
> > contour for
> > > optimum flow.
biggie,
> > but the
the
> > ports is
be
> > done to
> > removed and
porting
> > will
engine
> > > operating range.
the
> > same
Subaru
> > engines,
> > whatnot.
stay
> > there all
area
> > under
> > > the power curve.
25%
gain
> > friction, while
volumetric
rpm's
> > for an
do a
valvetrain
dependent
> > on how
> > lifters,
with
> > the
5%
> > to 10%
> > increase?
> > friction,
usually
> > somebody
take
> > advantage
greater
> > than the
> > > 10%.
provide
> > more torque
lower
> > engine
sometimes
> > even, a
> > cams, are
of
> > the
> > spent
> > valvetrain mass.
lifting
> > the valve
> > (acceleration
> > volumetric
> > > efficiency.
> > valvetrain mod,
amount of
> > power
desired on
> > the rpm
> > limited by
get
> > the bang
shop
off
> > the shelf.
a
> > top of the
> > > line valvetrain
drop
shop,
> > and pick
increase
> > in peak
increasing
not
> > choke off
downstream.
> > Once you
fast
> > do you
spend?
> > For me,
temperature
> > associated
the
> > cylinder
end
> > torque
most
> > everybody
> > > Larry Witherspoon
> > > 4260 W 182nd St.
> > > ssspoon@a...
> > BC-BFLegacyWorks-unsubscribe@e...
> > Your use of Yahoo! Groups is subject to
Check Email & Transfer files - Free Download
http://us.click.yahoo.com/omECdA/3XkDAA ... /XoTolB/TM
John Gillon
No, the twin turbo introduced in late 93 also introduced open deck blocks.
This also applies to the WRX but again I am not sure of exact dates and
models, although the WRX STI, type R, type RA are most definitely closed
deck.
It is a common performance mod, to add the superior twin turbo / WRX heads
to the single turbo Legacy EJ20 (which is closed deck) as they are a
"bolt-straight-on". I don't know if the same applies for the EJ22T.
John Gillon
Sent: Thursday, January 24, 2002 3:26 PM
heads
> AL(CO)
> solid
> about
> > the US version
> > John
> existing
> > heads
> engine?
> valve
> heads
> > > to
> diff
> > > in what
> > > starters, but
> to
> > > be very
> port
> > > contour for
> > > > optimum flow.
> biggie,
> > > but the
> the
> > > ports is
> be
> > > done to
> > > removed and
> porting
> > > will
> engine
> > > > operating range.
> the
> > > same
> Subaru
> > > engines,
> > > whatnot.
> stay
> > > there all
> area
> > > under
> > > > the power curve.
> 25%
> gain
> > > friction, while
> volumetric
> rpm's
> > > for an
> do a
> valvetrain
> dependent
> > > on how
> > > lifters,
> with
> > > the
> 5%
> > > to 10%
> > > increase?
> > > friction,
> usually
> > > somebody
> take
> > > advantage
> greater
> > > than the
> > > > 10%.
> provide
> > > more torque
> lower
> > > engine
> sometimes
> > > even, a
> > > cams, are
> of
> > > the
> > > spent
> > > valvetrain mass.
> lifting
> > > the valve
> > > (acceleration
> > > volumetric
> > > > efficiency.
> > > valvetrain mod,
> amount of
> > > power
> desired on
> > > the rpm
> > > limited by
> get
> > > the bang
> shop
> off
> > > the shelf.
> a
> > > top of the
> > > > line valvetrain
> drop
> shop,
> > > and pick
> increase
> > > in peak
> increasing
> not
> > > choke off
> downstream.
> > > Once you
> fast
> > > do you
> spend?
> > > For me,
> temperature
> > > associated
> the
> > > cylinder
> end
> > > torque
> most
> > > everybody
> > > > Larry Witherspoon
> > > > 4260 W 182nd St.
> > > > ssspoon@a...
milehial2000
Thanks for the information John I thought the price on these heads was
a little to attractive. Now I need a little help or advice from
someone who knows more about valves and lifters than I do. The US WRX
will pull well past 8000 rpm and my EJ22t floats the valves at
about 7200 rpm. Is this due to the boost pressure partially holding
the valves open the weight of the valve train the need for stronger
springs the hydraulic lifters or all of the above. I have some roller
type mechanical-adjustable rocker arms but the design of them makes it
more than a bolt on install. I wonder if they would make a substantial
improvement.
AL(CO)
blocks.
and
closed
> deck.
heads
> John Gillon
existing
> heads
like
US
> > AL(CO)
> > solid
sure
> > about
> > > the US version
> > > John
modifying
> > existing
> > > heads
> > engine?
> > valve
One
> > heads
> > > > to
make a
> > diff
> > > > in what
> > > > starters, but
going
> > to
> > > > be very
job.
> > port
> > > > contour for
> > > > > optimum flow.
> > biggie,
> > > > but the
reshaping
> > the
> > > > ports is
can
> > be
> > > > done to
be
> > > > removed and
> > porting
> > > > will
entire
> > engine
> > > > > operating range.
makes
> > the
> > > > same
> > Subaru
> > > > engines,
and
> > > > whatnot.
and
> > stay
> > > > there all
of
> > area
> > > > under
> > > > > the power curve.
> > 25%
more
> > gain
and
> > > > friction, while
> > volumetric
> > rpm's
> > > > for an
just
> > do a
> > valvetrain
> > dependent
> > > > on how
heads
with
> > > > lifters,
there
> > with
> > > > the
increase of
> > 5%
> > > > to 10%
> > > > increase?
mass,
> > > > friction,
> > usually
> > > > somebody
> > take
> > > > advantage
> > greater
> > > > than the
> > > > > 10%.
> > provide
> > > > more torque
> > lower
> > > > engine
> > sometimes
> > > > even, a
the
> > > > cams, are
size
> > of
> > > > the
well
> > > > spent
> > > > valvetrain mass.
> > lifting
> > > > the valve
rate
> > > > (acceleration
> > > > volumetric
> > > > > efficiency.
> > > > valvetrain mod,
> > amount of
> > > > power
> > desired on
> > > > the rpm
often
> > > > limited by
bucks to
> > get
> > > > the bang
you
> > shop
sticks
> > off
> > > > the shelf.
with
> > a
> > > > top of the
> > > > > line valvetrain
or
> > drop
you
> > shop,
> > > > and pick
> > increase
> > > > in peak
> > increasing
does
> > not
> > > > choke off
> > downstream.
> > > > Once you
how
> > fast
> > > > do you
> > spend?
> > > > For me,
> > temperature
> > > > associated
getting
> > the
> > > > cylinder
low
> > end
> > > > torque
> > most
> > > > everybody
> > > > > Larry Witherspoon
> > > > > 4260 W 182nd St.
> > > > > ssspoon@a...
John Gillon
The WRX uses under-bucket shims, which are about the shape and size of a M&M
sweet (if you have those in the USA) and these sit beneath the lifter
(called a bucket due to shape). ie. between the lifter and the valve stem.
These can never be displaced, and are the preferred high-performance
solution.
The twin turbo style over-bucket shims are about a 20cm flat disk that sits
in a recess on the top of the lifter. ie. between the cam and the lifter.
These shims have been known to become displaced at high rpm.
I did not realise that the EJ22 uses rocker arms! Yes, the rev limitations
will be a combination of the weight of the entire valve train, and hydraulic
lifters that usually suffer from "pump-up" when rev limits are exceeded.
Heavier springs are a common solution to increase rev limits, but introduce
more weight and stress on the valve train.
If the bore size and block jacket / galleries of an EJ22T are the same as an
EJ20, I would go for the later model DOHC heads (under-bucket or over-bucket
shims). Anyways, the name of the turbo game is to build torque, as peak hp
is around 6500rpm... why do want to rev much further than that?
John Gillon
Sent: Friday, January 25, 2002 3:24 AM
heads
> improvement.
> AL(CO)
> blocks.
> and
> closed
> > deck.
> heads
> > John Gillon
> existing
> > heads
> like
> US
> > > AL(CO)
> > > solid
> sure
> > > about
> > > > the US version
> > > > John
> modifying
> > > existing
> > > > heads
> > > engine?
> > > valve
> One
> > > heads
> > > > > to
> make a
> > > diff
> > > > > in what
> > > > > starters, but
> going
> > > to
> > > > > be very
> job.
> > > port
> > > > > contour for
> > > > > > optimum flow.
> > > biggie,
> > > > > but the
> reshaping
> > > the
> > > > > ports is
> can
> > > be
> > > > > done to
> be
> > > > > removed and
> > > porting
> > > > > will
> entire
> > > engine
> > > > > > operating range.
> makes
> > > the
> > > > > same
> > > Subaru
> > > > > engines,
> and
> > > > > whatnot.
> and
> > > stay
> > > > > there all
> of
> > > area
> > > > > under
> > > > > > the power curve.
> > > 25%
> more
> > > gain
> and
> > > > > friction, while
> > > volumetric
> > > rpm's
> > > > > for an
> just
> > > do a
> > > valvetrain
> > > dependent
> > > > > on how
> heads
> with
> > > > > lifters,
> there
> > > with
> > > > > the
> increase of
> > > 5%
> > > > > to 10%
> > > > > increase?
> mass,
> > > > > friction,
> > > usually
> > > > > somebody
> > > take
> > > > > advantage
> > > greater
> > > > > than the
> > > > > > 10%.
> > > provide
> > > > > more torque
> > > lower
> > > > > engine
> > > sometimes
> > > > > even, a
> the
> > > > > cams, are
> size
> > > of
> > > > > the
> well
> > > > > spent
> > > > > valvetrain mass.
> > > lifting
> > > > > the valve
> rate
> > > > > (acceleration
> > > > > volumetric
> > > > > > efficiency.
> > > > > valvetrain mod,
> > > amount of
> > > > > power
> > > desired on
> > > > > the rpm
> often
> > > > > limited by
> bucks to
> > > get
> > > > > the bang
> you
> > > shop
> sticks
> > > off
> > > > > the shelf.
> with
> > > a
> > > > > top of the
> > > > > > line valvetrain
> or
> > > drop
> you
> > > shop,
> > > > > and pick
> > > increase
> > > > > in peak
> > > increasing
> does
> > > not
> > > > > choke off
> > > downstream.
> > > > > Once you
> how
> > > fast
> > > > > do you
> > > spend?
> > > > > For me,
> > > temperature
> > > > > associated
> getting
> > > the
> > > > > cylinder
> low
> > > end
> > > > > torque
> > > most
> > > > > everybody
> > > > > > Larry Witherspoon
> > > > > > 4260 W 182nd St.
> > > > > > ssspoon@a...
milehial2000
I have seen the large overbucket shims in a few EJ20 motors. It seems
that the '96-'98 heads could be usable but it would be a big
improvement if they were a later model with the under bucket shims.
It sounds like the later model heads are very close to the new US WRX
heads. The reason that we try for higher rpm here in the US is that we
seem to get shorted all the way around. On the bottom end we don't
have the turbo the rest of the world gets and we are limited on the
top end also. A big part of the high rpm problem is fuel, the factory
does not give anything extra when it comes to fuel pumps and when that
is solved the rev limiter is in the way.
of a M&M
lifter
stem.
> solution.
that sits
lifter.
limitations
hydraulic
exceeded.
introduce
same as an
over-bucket
peak hp
> John Gillon
existing
> heads
was
WRX
holding
stronger
roller
makes it
substantial
> > improvement.
> > AL(CO)
deck
> > blocks.
dates
> > and
definitely
> > closed
> > > deck.
WRX
> > heads
are a
EJ22T.
> > > John Gillon
modifying
> > existing
> > > heads
would
> > like
the
> > US
> > > > AL(CO)
are
> > > > solid
not
> > sure
> > > > about
> > > > > the US version
> > > > > John
> > modifying
> > > > existing
> > > > > heads
EJ20tt
> > > > engine?
it's
> > > > valve
Formula
> > One
> > > > heads
> > > > > > to
> > make a
> > > > diff
> > > > > > in what
for
> > > > > > starters, but
are
> > going
> > > > to
> > > > > > be very
porting
> > job.
areas of
> > > > port
> > > > > > contour for
> > > > > > > optimum flow.
no
> > > > biggie,
> > > > > > but the
> > reshaping
> > > > the
> > > > > > ports is
that
> > can
> > > > be
> > > > > > done to
can
> > be
> > > > > > removed and
head
> > > > porting
> > > > > > will
> > entire
> > > > engine
> > > > > > > operating range.
> > makes
> > > > the
> > > > > > same
Market
> > > > Subaru
> > > > > > engines,
Porches
> > and
> > > > > > whatnot.
rpm
> > and
> > > > stay
> > > > > > there all
LOT
> > of
> > > > area
> > > > > > under
> > > > > > > the power curve.
15%
> > > > 25%
67%
> > more
> > > > gain
mass
> > and
> > > > > > friction, while
better
> > > > volumetric
higher
> > > > rpm's
> > > > > > for an
also
> > just
> > > > do a
> > > > valvetrain
increase.
greatly
> > > > dependent
> > > > > > on how
doing
> > heads
also
> > with
> > > > > > lifters,
up
> > there
> > > > with
> > > > > > the
> > increase of
> > > > 5%
> > > > > > to 10%
10%
> > > > > > increase?
lower
> > mass,
> > > > > > friction,
But
> > > > usually
> > > > > > somebody
desire to
> > > > take
> > > > > > advantage
much
> > > > greater
> > > > > > than the
> > > > > > > 10%.
to
> > > > provide
> > > > > > more torque
at
> > > > lower
> > > > > > engine
or
> > > > sometimes
> > > > > > even, a
and
> > the
> > > > > > cams, are
the
> > size
> > > > of
> > > > > > the
too
> > well
> > > > > > spent
lower
> > > > > > valvetrain mass.
also
> > > > lifting
> > > > > > the valve
ramp
> > rate
> > > > > > (acceleration
greater
> > > > > > volumetric
> > > > > > > efficiency.
before a
> > > > > > valvetrain mod,
same
> > > > amount of
> > > > > > power
where
> > > > desired on
> > > > > > the rpm
heads
> > often
> > > > > > limited by
> > bucks to
> > > > get
> > > > > > the bang
where
> > you
> > > > shop
> > sticks
> > > > off
> > > > > > the shelf.
20%
> > with
> > > > a
> > > > > > top of the
> > > > > > > line valvetrain
hundred,
> > or
> > > > drop
where
> > you
> > > > shop,
> > > > > > and pick
additive)
> > > > increase
> > > > > > in peak
> > > > increasing
system
> > does
> > > > not
> > > > > > choke off
> > > > downstream.
> > > > > > Once you
ask
> > how
> > > > fast
> > > > > > do you
to
> > > > spend?
> > > > > > For me,
> > > > temperature
> > > > > > associated
> > getting
> > > > the
> > > > > > cylinder
enhances
> > low
> > > > end
> > > > > > torque
armpits,
> > > > most
> > > > > > everybody
> > > > > > > Larry Witherspoon
> > > > > > > 4260 W 182nd St.
> > > > > > > ssspoon@a...
Full setup in 2 minutes! - Free Download
http://us.click.yahoo.com/pmECdA/2XkDAA ... /XoTolB/TM
Locked
