i have wondered about my sunroof ever since i bought the car 6 months ago. the sounroof works perfectly about 40-50% of the time, and at the moment is stuck open. anybody had similar problems? any ideas?
Thanks, Teague
inconsistent sunroof
'99 Impreza L 2.2 powa!
"If at first you don't succeed, failure may be your style."
sunroof quirks
hey teaguespeed thats a common problem, just take some time cleaning it very well ie the tracks and all visible parts and remove that useless alluminum pc that pops up. that was causing problems with mine and the easiest solution is to just take it off. lubricate the runners and rubber seals as they tend to dry out on our oldsunbaked legacys. sometimes that switch might need some electrical gremlin spray/cleanup. and dont forget to clean out those drain lines, i dont know how many times that sunroof peed on the passenger before i realized the previous owner never cleaned them out
- Spelling Nazi
i've done the switch on my previous crx, all you gotta do is take it apart, alot of the time electrodes get black crap on them, all you need to do is get a piece of sandpaper, or nail file and scratch it off...
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
