Rear toe adjustment?
MCO-Ryan
Post by MCO-Ryan »
Hi all,
Is it possible to adjust the rear toe on our cars? I bought my 93 turbo in February, and it's really been hard on the outside edges of the rear tires. My fronts are wearing evenly, it's just the rear that's bad. I can't think of another reason it would be wearing them like this.
Ryan
Ryan Huber
VA3AWD
2004/2005 VP Navigational Rally, RallySport Ontario
93 Legacy Turbo 5MT, daily driver/TSD rally car
92 Legacy LS 4EAT, retired (309,000kms), parts donor
NuwanD
Post by NuwanD »
i think the uneven wear pattern is from too much positive camber rather than toe... i could be wrong, is the worn area smooth or kinda chewed up? not sure of the proper way to adjust it however
Nuwan
1992 Open Class Legacy Turbo
2004 Forester XT
2000 Impreza 2.5RSC (Supercharged)
1990 Rover Mini 1000
paf
Post by paf »
from what I have read in my haynes manual
rear camber is not ajustable but toe is adjustable
1990 FWD Legacy Wagon Base
toe is adjustable.....but as pointed out......I don't think it is the problem.
It sounds like camber. The rear is not "officially" adjustable....however they can usually loosen up the bolts and tweak things.
Or other cause could be from improper inflation or rotation.
ej22t
Post by ej22t »
Ryan, I think you better go to Woodbridge Alignment shop to take an alignment check, it cost around $75-$90 for all 4wheeles.
Ben
92 Legacy turbo with EJ20G engine swap \(^0^)/
MCO-Ryan
Post by MCO-Ryan »
Thanks for the input guys, if it would help I can email a picture to someone to host, to give an idea of what the wear is like. The tires have only been on the car for about 4500kms, Kumho 712s, running at 32psi all around. Visually camber looks good, I can't tell how the toe is though. A mechanic friend thought I likely had big toe in, I guess we shall see.
As for alignment shops, I have a friend who owns a suspension shop with an electronic alignment machine, I just didn't think it was adjustable in the back. I guess I'll have to have it looked at.
Ryan Huber
VA3AWD
email me the pic
ciper
Post by ciper »
Haha, Ive got near infinite adjustment for toe plus camber adjustment with the benefit of new bushings all from one part, the MRT adjustable arms.
MCO-Ryan
Post by MCO-Ryan »
OK, here's a couple pics. The first is the right front, for a baseline comparison. The second is the right rear, which is a little worse than the left rear.
and
Ryan Huber
VA3AWD
