----- Original Message -----
To: BC-BFLegacyWorks (E-mail) <mailto:BC-BFLegacyWorks@yahoogroups.com>
Sent: Thursday, February 28, 2002 78 PM
Subject: [BC-BFLegacyWorks] Exhaust sizing...
This is mainly aimed towards Rod since he was usin the turbo setup I would possibly consider in the future, but I'm open to any input.
Ok question is....there's a place where I could get basically a complete custom mandrel bent cat back system for around $200......I would probably spend a little more, and do the entire system to the header pipe and get a high flow cat.....
But anyway....my question is sizing. I don't want to get something too small.....in the event I do decide to put a turbo on later.....yet I don't want to get something to large, and kill the way the car drives now.
I am leaning towards 2.25" system with high flow cat.....I really haven't given much thought about muffler.....I really don't want something that is going to be overly noisy.....maybe make some noise when you are revving in the higher rpms....sorta like takin the intake silencer provides. But I want to be able to drive down the freeway and not hear a drowning exhaust sound.
So first thing....which was meant for rob...but anyone feel free to answer. If I get the turbo kit.....I don't think I'd go as nuts as you....and go with alcohol injection and what not. Probably would end up stickin with the same turbo...the stage 3 turbo upgrade....and would probably go with the stage 2 kit that has an intercooler. I'm assuming I really wouldn't be able to run boost much higher then 6psi....8psi at the very most...but I'm really not sure.
So with those boost numbers in mind.....do you think a 2.25" exhaust system is adequate enough? Or would a 2.5" be more suited?
If there is goin to be a decent difference between the 2.25" and 2.5" I'll just wait and do the exhaust when I do the turbo.
Other thing would be mufflers....anyone have any suggestions....something that would fit what I'm lookin for as described above. I'd also like dual tips......just like those better
Thanks for any insight.
Josh Colombo
<mailto:Josh@surrealmirage.com> Josh@surrealmirage.com **NEW**
of beats and rhythm" - ME
