Don't know where the thread's coming from and might just be butting my nose in, but saw this;
Uploaded by : legacycentral <legacycentral@yahoo.com>
Description : 92 Legacy ECU diagram
Could you take a look and see if it has that pin you were talking about?
Maybe worth a double check because . . .
MPFI Control Unit shows links to AT (Automatic Trans?) CONTROL UNIT at a16 on lower left, and INHIBITOR SWITCH (AT) on upper right.
If you are interested in a Turbo Legacy ECU, I don't think this is it. I think we have an N/A ECU here, because I believe the turbo ECU does not talk to the auto trans TCU, but the N/A ECU does.
Larry Witherspoon
Access Your PC from Anywhere
Full setup in 2 minutes! - Free Download
http://us.click.yahoo.com/pmECdA/2XkDAA ... /XoTolB/TM
92 Legacy ECU diagram turbo or N/A ?
