oil catch can /emission mods
Locked
Josh Colombo
Post by Josh Colombo »
Rod,
Any issues or differences in doing this setup on a N/A engine? I want to do this to keep fresh air only.
As far as the MAF sensor knowing exactly how much air is entering through the hoses. I believe it would be considered a closed loop system, so the air has already been measured by the MAF sensor, it's just dirty air.
Josh Colombo
<mailto:Josh@surrealmirage.com> Josh@surrealmirage.com **NEW**
of beats and rhythm" - ME
-----Original Message-----
Sent: Friday, March 29, 2002 71 PM
Subject: [BC-BFLegacyWorks] oil catch can /emmission mods
try this idea i used. Costs next to nothing and works beautifuly.......
Purpose of this : to stop oily, blow-by gases getting into the air
> let.
> -General Description (diagram attached) of workings, normally.....
> At part or nil throttle, the blow-by gas in the crankcase is drawn
> into the inlet manifold through the connecting hoses and PCV valve by
> strong vacuum in the inlet manifold (strong vacuum opens the PCV
> valve). Under these conditions, fresh air is introduced into both the
> rocker covers via the air inlet duct and connecting hoses. The
> crankcase (blow-by)gases, mixed with the fresh air, are drawn through
> the hoses, PCV valve and into the inlet manifold.
> At open throttle, under turbo boost, positive pressure is created in
> the inlet MANIFOLD ,ie. the inlet MANIFOLD has no vacuum and hence
> the PCV valve is shut. Instead, the turbocharger asking for maximum
> air, is creating a kind of vacuum in the air inlet ducting.
> Under these conditions the system works in reverse. Blow-by gases are
> drawn into the air intake duct via the rocker cover hoses and hose
> off the crankcase, prior to the PCV valve (shown in diagram below).
> During these conditions, the inlet air being fed is not 100% fresh
> air but a mixture of fresh air and blow-by gases. This also leaves an
> oily film, over time, in the inlet ducting, turbo and intercooler.
> 100% fresh air would be a better alternitive.
> What I did.....
> 1. The hoses from the both the rocker covers come together as one and
> lead to the air inlet duct. I have pulled this hose out and plugged
> the hole in the air inlet duct. On the end of the pulled out hose, I
> have fitted an oil foamed filter, a mini version of a uni-fliter if
> you like. Now the system can draw fresh air into the rocker covers
> whenever required but will not allow blow-by gaes to be drawn into
> the air inlet duct. It now 'breathes'. This is similar to the pre-
> emission days when engines used to 'breathe' through the rocker cover
> oil filler cap.
> 2. There is another hose that links from the air inlet duct, to the
> crankcase hose and PCV valve. (see diagram) I have plugged the
> section leading from the air inlet duct. This now allows crankcase
> vapours to be drawn in the inlet MANIFOLD via the PCV valve but stops
> the crankcase vapours being drawn into the air inlet DUCTING. This is
> now 'one-way' if you like.
> I realize this is not allowed under emission control laws, in Aust, but the
> only thing that can be visually seen is the tiny foam air filter.
> This must make a difference as the airflow meter now has the exact
> amount of air entering the engine, as is couldn't know what was being
> drawn in through the blow-by hoses. Physically I noticed that the
> chrome tailpipes on the rear muffler are not 'sooting' up as much..
> I also removed the air ducting / intercooler and cleaned the oily
> film off everything and it is still spotless. I have been running
> like this now for over a year.
> > Regards, Rod... in OZ
ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1818248.33 ... 847665/R=1>
<http://us.adserver.yahoo.com/l?M=215002 ... =114376996>
rodeddy
Post by rodeddy »
i don't know the setup on a N/A engine.
Rod
--- In BC-BFLegacyWorks@y..., "Josh Colombo" <josh@s...> wrote:
> Rod,
just dirty air.
> Josh
> Josh Colombo
> <mailto:Josh@s...> Josh@s... **NEW**
> From: Rod [mailto:melrod@o...]
> To: BC-BFLegacyWorks@y...
beautifuly.......
> > let.
drawn
valve by
the
through
in
hence
maximum
are
hose
below).
fresh
leaves an
> > What I did.....
and
plugged
hose, I
if
covers
into
pre-
cover
> > oil filler cap.
the
crankcase
stops
This is
Aust, but the
exact
being
much..
> ADVERTISEMENT
<http://rd.yahoo.com/M=215002.1818248.33 ... upweb/S=17
05064983:HM/A=847665/R=0/*http://ads.x10.com/?
bHlhaG9vbW9uc3RlcjcuZGF0=1017449814%
3eM=215002.1818248.3328688.1261774/D=egroupweb/S=1705064983:HM/A=84766
5/R=1>
M=215002.1818248.3328688.1261774/D=egroupmail/S=1705064983:HM/A=847665
/rand=829781853>
> BC-BFLegacyWorks-unsubscribe@e...
> zZz
Access Your PC from Anywhere
Full setup in 2 minutes! - Free Download
http://us.click.yahoo.com/pmECdA/2XkDAA ... /XoTolB/TM
Locked
