For $90 shipped, I got control arm bushings, trailing arm bushings, sway bar, and shifter bushings. The kit I got is #16-2001 It's listed for 97-05 impreza or something like that.
They're always on ebay:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0092253365
My initial thoughts on the kit is that all the bushings but the front swaybar ones will work on the Legacy.
I won't be installing the swaybar bushings, nor the shift bushing, so I'll try and sell those.
So we'll see how much a chore installing control arm and trailing arm bushings are.
My Predictions:
The front control arm bushing should be easy, since it's 2 pieces. The rear bushing will probably suck, and I might just forget about it and buy the whiteline ALK instead. That way I've got poly and alk without the hassle.
Rear trailing arm front bushing is gonna suck. It's huge and one piece. The rear bushing will be a little better, since it's 2 pieces. I'm not quite sure where it goes though. I'm assuming it replaces the bottom bushing in the hub, but I'm not sure.
If anyone was considering doing this, I took the dive, and I'll keep updating this thread as I progress. When I get home, I'll get the part #'s for just the control arm and trailing arm packages, since I think those are the best pieces out of this kit.
