Sedan vs. wagon rears (struts)
91White-T
Post by 91White-T »
Search turned up that they aren't interchangeable. Why exactly is that, are they phyiscally different, and how so?
edit: struts that is
98 Ford Contour V6 24V 5MT
98 Chevy Camaro Z28 LS1 6MT
91 Rio Red SS 5MT Sold
91 Pearl White SS 4EAT RIP
Are you talking about the same year cars & same drivetrain....or different years?
As long as they are both AWD and from the same range of years 90-91 and 92-94.....you should be able to use them.
The wagon struts will typically have a higher damping rate, but that really won't keep you from running them.
91White-T
Post by 91White-T »
Thanks, I was actually tryin to figure out if wrx sedan struts will work on a 91 wagon. Basically what I want to know is if the bottom two holes will line up, and if the piston comes up to the same place.
hmmm.....I think they will....I know the top mounts are different in the rear for the wrx sedans, but the shaft on the strut still is threaded the same.
scottzg
Post by scottzg »
check out the spring rates. physically fitting is a far cry from an improvement.
91White-T
Post by 91White-T »
I'm not actually using the springs, just the struts with coilover sleeves and stock topmounts. So the strut body should fit?
yeah, I don't see why not.
91White-T
Post by 91White-T »
Thats what I assumed too, just wanted to double check. Thanks!
scottzg
Post by scottzg »
I believe the strut body is identical front to rear. If this is the case, you might consider putting the front struts in back and vice versa.
LaureltheQueen
Spelling Nazi
Spelling Nazi
Post by LaureltheQueen »
the part # on the agx struts is exactly the same from wagon to sedan
Laurel Tuning Stage 15
92 Touring Wagon 5MT 16G
scottzg wrote:I believe the strut body is identical front to rear. If this is the case, you might consider putting the front struts in back and vice versa.
The front and rear strut bodies are different, and are not interchangeable.
The Scooby
Post by The Scooby »
so right now i have sedan struts/springs on my 94 wagon. and the rear is saging is that because the springs are for a lighter int he rear sedan? the struts are good, but are the spring rates different?
1986 GL wagon
EJ'ed and Lifted
