I have a 91' legacy wagon with a 93' 2.2 N/A motor with about 140k on it, It runs great! I want a turbo though!! Should I look for a 2.2 turbo motor to swap in or should I convert the 2.2 N/A that I have in it to a turbo?? Pros/Cons etc.
Turbo Question
Trailblazer
Turbo Question
91' Legacy L Wagon w/93' 2.2 motor
http://members.cardomain.com/trailblazer24
BAC5.2
Swap it.
It's amazing how many times this has been gone over.
Simply enough, you won't get much out of the N/A block in terms of turboing. Why would you bother when a whole turbo legacy setup would be more efficient use of dollars, and be more durable as well.
OEM Turbo > Aftermarket turbo.
http://bbs.legacycentral.org/viewtopic. ... turbo+swap
http://bbs.legacycentral.org/viewtopic. ... 11&start=0
http://bbs.legacycentral.org/viewtopic. ... 12&start=0
http://bbs.legacycentral.org/viewtopic. ... 81&start=0
http://bbs.legacycentral.org/viewtopic. ... 97&start=0
http://bbs.legacycentral.org/viewtopic. ... 65&start=0
98 LGT
BAC5.2
That's a shit load of links.
Thanks for doing what I was to lazy to do J-Money
