My first post on this board!
Hey fellas, I have a 91 legacy wagon with automatic and 4wd. Lately it has been slow to shift into reverse. when I shift into reverse, it will not engage immediately, and will rev up and then catch. any ideas? tranny fluid looks ok.
thanks,
jeremy
thanks,
jeremy
so can I fill a little more tranny fluid in without risking blowing a seal? Some of my friends who are into 4x4ing overfill slightly to compensate when they are at a steep angle. those are strong chevy trannys though...
anyone think the subaru seals can take it?
Jeremy
Jeremy
Make : SUBARU Model : LEGACY Year : 1990
NHTSA CAMPAIGN ID Number : 91V082000 Recall Date : MAY 30, 1991
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Potential Number Of Units Affected : 76000
Summary:
UNDER CERTAIN LOAD CONDITIONS, THE PARK GEAR MAY NOT DISENGAGE IMMEDIATELY WHEN THE TRANSMISSION LEVER IS MOVED FROM PARK TO REVERSE.
Consequence:
DELAYED RELEASE OF TRANSMISSION FROM PARK CAUSES DELAYEDAND POSSIBLY ABRUPT VEHICLE MOVEMENT THAT COULD RESULT IN LOSS OF VEHICLECONTROL AND AN ACCIDENT.
Remedy:
INSTALL A MODIFIED PARKING BRAKE PAWL TO PREVENT DELAYED RELEASE INTO REVERSE GEAR.
Notes:
SYSTEM: TRANSMISSION PARK GEAR.VEHICLE DESCRIPTION: PASSENGER CARS WITH ELECTRONICALLY CONTROLLED AUTOMATICTRANSMISSIONS (4EAT).
Summary:
Consequence:
Remedy:
Notes:
1990 FWD Legacy Wagon Base
If you give the dealer your vin number they should be able to run it and see if this recall has been performed yet. If it is not, they should honor it.
It will not affect your parking brake. What it modifies is the parking pawl, which is like a "catch" that keeps the transmission from moving.
well, it does it more from drive than from park. its real bad sometimes, have to wait a few seconds, but then sometimes its immediate. doesn't matter if its on a slope or anything. the TC draining definitely sounds plausible. I'm just too lazy/busy to go to the dealer.
