It seems to be a point of confusion, I have heard many different discussions about the differential ratios.
Every NA automatic legacy I have took the time to check has had the 4.11 rear diff. I have also seen a 5 speed NA with 4.11 gearing.
So was it that all non turbo legacy got 4.11 (5 speed/auto)?
The 92-94 automatic n/a legacies had 3.90 gearing. I know the 92 & 93's are this way, and I'm assuming the 94 is the same as well.
The manuals were all 4.111
