Waterpump interchangeability b/t wrx and turbo legacy
Project_Legacy
Post by Project_Legacy »
nice. i think im just gonna buy a WRX water pump for my motor rebuild then. seems easier to find/get. so a coolant bypass cap? where would i get that? an auto parts store?
00 5MT AWD 2.5 RS - New Project
Yes.
I looked at the WRX oil cooler today, and it is different then forester one I have. The outlet pipe on the wrx oil cooler is angled upwards while the forester one is horizontal. There's a possibility I can make it work, I'm just not sure if it will interfere with the header. I'll have to check it out as I dissamble things.
If not, I'll just have to sell the setup I have to one of you n/a guys.
here's pics of the forester setup
http://www.main.experiencetherave.com:8 ... oilcooler/
THAWA
Post by THAWA »
The forester hard line wont work. I've tried, it runs into the exhaust.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
I know the hard line won't work, I'm talking about the oil cooler itself.
Did you use the forester oil cooler, or one other one? Was it from an n/a motor or turbo motor.
THAWA
Post by THAWA »
I used a WRX oil cooler because it looks like it flows oil better.
How does it look like it flows oil better? It's the same exchanger with the pipe bent slightly upward.
THAWA
Post by THAWA »
This is where my lazy self needs to go take pictures ;)
The design of the oil flow on the inside looks less restrictive on the wrx cooler. It could not make any difference or the turbo legacy one could flow more, the wrx one just doesn't look as restrictive. It's a different design than the turbo legacy. As far as coolant flow goes, I couldn't tell ya. But it just looks like a better unit than the old one.
Ok....I thought you were comparing the wrx one to the forester one.
Fitted the forester oil cooler on the ej22t motor. The one line is too close to the header pipe. I'm going to have to try and get a hold of a WRX one.
http://www.main.experiencetherave.com:8 ... ooler1.jpg
http://www.main.experiencetherave.com:8 ... ooler2.jpg
IronMonkeyL255
Post by IronMonkeyL255 »
I love my car.
*Already has factory-installed oil cooler*
Rio Red '91 Legacy SS
kidwired
Post by kidwired »
how much was the wrx cooler?
Goodbye my sweet, parting is such sweet sorrow....1993 BC6 , Saab IC, with xtras Hallman MBC, HKS FCD , wrx exaust.
dzx
Post by dzx »
Did all wrx's come with them? usdm
///M
'93 Legacy SS - part out
THAWA
Post by THAWA »
It was either 25 or 50 on ebay
Yes, infact I believe all new gen turbos except the 92-94 legacys have oil coolers. Don't quote me on that though.
THAWA wrote:Yes, infact I believe all new gen turbos except the 92-94 legacys have oil coolers. Don't quote me on that though.
Pretty sure your correct on that. Turbo foresters have them as well....and I'm assuming the LGT has one too.
dzx
Post by dzx »
Sounds like 92-94 got shafted
///M
biggreen96
Post by biggreen96 »
I recently put a wrx waterpump onto my 93 without factory oil cooler. I went to the store and got a little cap(get a hoseclamp too so it wont shoot off.) and capped off the extra nipple. It was very simple:
Arctic Assassian
Post by Arctic Assassian »
lol all that talk, and there's the answer. I appreciate this though, because I'm going to put this waterpump on my 91, because it's newer! peace
-Adam
Kickin' it old-school.
bmxpunk
Post by bmxpunk »
Odd this popped up again... I am sticking the Wrx waterpump on my car this weekend along with an 07 Sti oil cooler/heat exchanger.
2011 Mini Countryman S All4
1970 Honda Ct90
2001 Forester S of Doom - mowed down by a Cummins
1994/5/6/01/02/03/04/06/07/08 Impregacy OUtback SS STi Type R money pit- NEW RALLYCAR!!
biggreen96
update: that little cap sucks, I remember it broke within a month. It's the kind that Schucks, Autozone, Napa etc sells. Avoid it. I used a smaller coolant hose with a bolt jammed and clamped into the end as a heavy duty cap.
ciper
Post by ciper »
Remember if you get a "Turbo" pump you also need the "Turbo" thermostat housing.
