Foam rubber for tmic?
Front, Top, Air, Water.
kidwired
Post by kidwired »
I'm thinking of installing foam rubber around the top of ic so its sealed to hood directing more air thru it and keeping from rattleing under the hood. Obviouly it would have to handle the heat. Somthing like a 3-4" wide strip like neoprene mat'l in pipe insulation.
Suggestions?
Goodbye my sweet, parting is such sweet sorrow....1993 BC6 , Saab IC, with xtras Hallman MBC, HKS FCD , wrx exaust.
J-MoNeY
Post by J-MoNeY »
Sounds feesible. Do it and let us see what it looks like.
98 LGT
professor
Post by professor »
you should be all right with the neoprene, it'll handle around 200F continuously (until it falls apart from heat aging, but at least its cheap)
that should be enough, but if not I can look up something that will handle higher temps
free5ty1e
Post by free5ty1e »
I'd also recommend you put something a little beefier between your TMIC and the engine, while you're at it. One of those laser-aimed thermometers will tell you how bad your heat soak is. My Saab 900 TMIC had ~100 degree air entering it (top fin) and ~120 degree air leaving it (bottom fin, right by engine) when sitting at idle.
-Chris
91SS 4EAT stock, 200k mi
kidwired
Post by kidwired »
yeah, I considered some kind of heat sheild but it cant be anything that blocks airflow on the underside. :?
