04 pots front calipers for std diam/OEM discs
djorge
Is there any option? I almost bouth a set of those RS from subaruparts.com, but suddenly they were not anymore supplied; there use to be also some option from Perrin´s that either no longer exhist;
BAC5.2
what are 04 pots?
OEM 4-pots from Subaru fit on stock 11.4" WRX rotors only.
Check on nasioc in the vendor group buy forum. Jamie is doing a group buy on the 4-pots.....and can get the rear 2-pots, but at 800 bucks....and a lot of work, I personally don't think it's worth it.
If I get them some day, I'll probably try and nab them from a junk yard.
