Doors dont lock?
JOE590ME
Doors dont lock?
Post by JOE590ME »
On my 92 legacy, I can lock all the doors, but evertime that I close the driver or passenger side doors, they unlock, is there something I can do or do I take it to the Subaru dealer?
Post by entirelyturbo »
Mine doesn't do this, but on my friend's 91 turbo, I pull the handle while I close the door to keep it locked. Many older Japanese cars do that; I don't know why.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
IronMonkeyL255
Post by IronMonkeyL255 »
Mine lock randomly.
The driver's door locks when you pull on the inside door handle. The rear driver's side door locks when you open it then close it again.
Rio Red '91 Legacy SS
scottzg
Post by scottzg »
I have to hold the drivers side handle up.
It's always been like that.
Warp3
Post by Warp3 »
Actually, IronMonkey, you are referring to a different problem than the other two posts. :)
The first issue is by design, I believe, to prevent you from locking your keys in the car (as you have to either lock the door from outside with the key or hold the exterior door latch open while you close the door, thus making sure that you are intentionally locking the door). This is very common behavior on cars built around this time (in fact, I believe my '86 RX does this as well, but can't recall since I usually lock it with a key anyway).
The second issue is a side-effect of the locking mechanisms wearing out over time (my left-rear door does this). Basically, the symptom is that pulling the interior door latch rotates the lock button as well, thus relocking the door instead of actually opening it. The workaround is to hold the lock button in the unlocked position (to prevent it from moving) while pulling the latch. From my conversations with Dale at Boxer4Racing and from reading posts here, this seems to be a very common issue on the early Legacies.
Shane
2006 Subaru WRX TR
1989 Toyota MR2
Here's a fix to the 2nd issue Warp mentioned. Takes a while if you've never done it before.
http://www.geocities.com/hobiegary/locks.html
Note: chiseling the door wasn't needed for my wire to fit between the lock mechanism and the sheet metal
tris91ricer
Title Whore
Post by tris91ricer »
Nice link, Reed!11 I've had that bookmarked for some time now, and I completely forgot about it for this discussion. Good call.
[b]'92 L Sedan[/b]
EJ20g 4.11 5sp LSD
[/quote]
JOE590ME
Post by JOE590ME »
Thanx alot, I guess you have to hold the handle up whie u shut the door, this is my first subaru that i am rebuilding, and i have no idea about them
Joe
