Replacing the front door window rubber seal
georryan
Post by georryan »
Hey guys, my front window is making wind noise on my driver's side door. I've seen lots of talks about this but I know for a fact that it is the rubber seal that hugs window as it comes up. It sits on the inside of the rearview mirror and the plastic triangle. I'd like to replace that thing, and I feel real silly for asking this but how does that thing come out?
I had the door apart last week fixing the locking mechanism and glanced at that rubber but couldn't figure out how to take it out.
Has anyone else pulled that off?
-Ryan
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
I believe you just pull.....or at least that's what the dude did that replaced my windshield.
georryan
Post by georryan »
Do I need to take off the side view mirror?
-Ryan
2014 Volvo S60 T5
If the rubber's in good shape you could just stick some 1/4" rubber tubing between the folds of the weatherstripping which helps force contact with the window. It's worked on mine for four years so far.
yeah....I used car stereo power wire. It's nice and flexible.
I've been wanting to get an old gasket and cut it up and put some more rubber behind the current one.
ciper
Post by ciper »
But all of you are wrong. :wink:
The technical fix involves spacers, the "ghetto" fix involves bending and compression the triangle portion. No reason to modify or replace when it can be done without tools.
georryan
Post by georryan »
Well I've tried the spacer in the rubber folds. That didn't work.
How do you compress the triangle piece cypher? I've tried pushing it together or bending the rubber closer together but it doesn't seem to stay.
-Ryan
2014 Volvo S60 T5
georryan
Post by georryan »
OH man my spelling is off today. Hey ciper, when you get to your name in my last post,.....just skip over that. :)
-Ryan
2014 Volvo S60 T5
ciper
Post by ciper »
On mine I had to bend it quite a bit farther than you would think it needed. The first time I did it it worked for quite a while, the second time I bent it further and it hasnt came back yet.
The spacer idea works too, I was just joking
Believe it or not I have been using this handle since about 95, so it has nothing to do with the matrix. How do you think I got the email of ciper @ hotmail, with a password that is currently LESS than what is allowed (as long as I dont change it its grandfathered in).
mikec
Post by mikec »
ciper wrote:How do you think I got the email of ciper @ hotmail, with a password that is currently LESS than what is allowed (as long as I dont change it its grandfathered in).
Not to be a nag or anything, but should you really be broadcasting that? Even if it is just this group? :)
georryan
Post by georryan »
Ok bend it, but how exactly did you do that?
Did you push the tringle piece and the side view mirror together? I'd be afraid I'd brake something. Or did you just bend the rubber seal's two ends together?
-Ryan
2014 Volvo S60 T5
ciper
Post by ciper »
Squeze the triangle together with the window rolled down. Use one hand on either side and have the door open. The rubber channel that the window slides in should close up while you have pressure on it.
You also have to bend the triangle inwards a little bit. Realize that everything flexes so you have to bend it beyond the flex point for the position to stay.
I've tried bending it, and didn't work. Don't know if I just didn't bend it enough......oh well.....
georryan
Post by georryan »
I got it. Sweet silence!.....reletively. I get quite a bit of road noise from the Potenza's.
I pulled (very carefully since I've had to broken ones already) the triangle piece out and then loosened up the mirror from the two bolts in side. Then I just squeezed the rubber seal to the point were the two ends that would go on either end of the window were pretty much squeezed together. I did this a few times. I sappose you could even use pliers to pull the two ends together as long as you don't scratch up your side view mirror or rip into the rubber of the seal.
Then all I did was put the two screws back in and the plastic triangle, took it for a test drive and just started to smile.
Thanks for the help guys.
-Ryan
2014 Volvo S60 T5
ciper
Post by ciper »
Good to hear, but why did you take it apart? Ive done this a couple times on my Legacy's and didnt need tools.
georryan
Post by georryan »
Well I probably didn't have to take it apart, but as I was putting pressure on that plastic triangle on th inside of the door, I started getting a little worried. I've already had two of those break, and yes the other two were in worse shape, but I didn't feel like breaking that one, so I pulled it out. Then I saw the two bolts holding the mirror on so i loosened those a bit so I could squeeze only the rubber seal together. It gave me a little more leverage I think, but your right, I probably didn't need to do it.
-Ryan
2014 Volvo S60 T5
