I have the new engine in the car, but the engine (torque converter)wont just click back into the tranny, is there something i have to do?
subject edit by jason
torque converter wont go back in
JasonGrahn
umm, there are steps? i didnt know that, me, my friend, my father, and my uncle all did this and we just disconnected everything and took the old engine out, and now we are puttin the new one in and we know how to hook everything up except getting the damn torqu converter back into the tranny, the TC is still connected to the engone, but i dont see how to put it back on if i were to take it off. does that help?
Matt Monson
- quasi-mod-o
You should have mounted the torque converter to the tranny before trying to put the engine in. You need to line it up and slide it on, and then put the engine in and bolt it to the flex plate through the timing hole in the top of the block...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
All_talk
What he said...Matt Monson wrote:You should have mounted the torque converter to the tranny before trying to put the engine in. You need to line it up and slide it on, and then put the engine in and bolt it to the flex plate through the timing hole in the top of the block...
Another note, I've had better luck re-stabing the TC with the "drive sleeve" clipped to the TC before you install it (I'm not sure you can do it any other way).
Gary
please search the drivetrain forum. others have had similar issues.
also...moving thread to appropriate forum.
mount to tranny first
Yes, you HAVE to mount the TConv to the tranny first,-It won't mount on the sleeve correctly if you still have it mounted to the flex plate.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
