torque converter wont go back in
JOE590ME
Post by JOE590ME »
I have the new engine in the car, but the engine (torque converter)wont just click back into the tranny, is there something i have to do?
subject edit by jason
Joe
JasonGrahn
Post by JasonGrahn »
what step in the install did you skip over?
-Jason Grahn
JOE590ME
Post by JOE590ME »
umm, there are steps? i didnt know that, me, my friend, my father, and my uncle all did this and we just disconnected everything and took the old engine out, and now we are puttin the new one in and we know how to hook everything up except getting the damn torqu converter back into the tranny, the TC is still connected to the engone, but i dont see how to put it back on if i were to take it off. does that help?
Matt Monson
Post by Matt Monson »
You should have mounted the torque converter to the tranny before trying to put the engine in. You need to line it up and slide it on, and then put the engine in and bolt it to the flex plate through the timing hole in the top of the block...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
All_talk
Post by All_talk »
Matt Monson wrote:You should have mounted the torque converter to the tranny before trying to put the engine in. You need to line it up and slide it on, and then put the engine in and bolt it to the flex plate through the timing hole in the top of the block...
What he said...
Another note, I've had better luck re-stabing the TC with the "drive sleeve" clipped to the TC before you install it (I'm not sure you can do it any other way).
Gary
please search the drivetrain forum. others have had similar issues.
also...moving thread to appropriate forum.
Bheinen74
mount to tranny first
Post by Bheinen74 »
Yes, you HAVE to mount the TConv to the tranny first,-It won't mount on the sleeve correctly if you still have it mounted to the flex plate.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
