Is it possible to put the one-touch automatic up button on the other window controls? I would only want them on the driver's door control, but that would be the coolest thing... just pop all four and watch them go all the way up or down. I don't know how the actual mechanism works on the one-touch button, but if someone could enlighten me .
I have been wondering about this since the first day I got the car. Hopefully someone has tried this by now.
Power window dreams...
The way the one-touch thing works is it uses some form of electrical load sensing device, and when the electrical load starts building up, it clicks off. Or at least that's how it was explained to me.
They make moduals for adding power window controls to your alarm system in your car. For eaxample, you'd like your windows to roll up when you arm the system. Clifford makes a unit that would make all window switches work as one touch. They were expesive from what I recall and one unit only did 2 windows.
Look here http://clifford.com/g5/access/default.asp#smartwindows
They are designed to work with alarms or a negative trigger but you can hook them up without an alarm and they will still fuction for what you want.
Mike
Mike
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
i did this to my 91 n/a 5MT back in 96. but i did it by putting automatic windows up and down on my alarm. (like mercedes) which made it so the drivers controls were all one touch. also had remote start, proximity sensors, and i had motors put in so all the doors would lock and unlock from the alarm control.
