EGT Probe - Best Location ?
morgie
Post by morgie »
Hi,
What could be the best location to put a EGT probe ?
1 - UpPipe : Near the engine, but may be dangerous for turbo if anything breaks.
2 - DownPipe / Near O2 Sensor : Not so far from source, can be used to analyse O2 Sensor, Not dangerous for turbo... but readings may be lower.
3 - ???
morgie
'98 4Runner V6 Manual 4x4.
ciper
Post by ciper »
Neither of the two!
As close to cylinder three as possible!!!
morgie
Post by morgie »
Hum, yeah the Evil cylinder ... but, standing in front of the engine, wich one is it ?
morgie
LegacyT
Post by LegacyT »
Yup. 4-6 inches from the flange on cylinder #3 (passenger side closest to the firewall)
Mark,
ciper
Post by ciper »
You could have traced the spark plug wire (your coil pack is labeled) :wink:
Shoot for 1400 F or 750 C as your target maximum.
RaZor
Post by RaZor »
What if the EGT is plugged on the downpipe? what reading should I get?
Aaron's ej22t
Post by Aaron's ej22t »
a reading that is not as accurate.
92 Legacy Turbo \ 5MT \ Silver
ciper
Post by ciper »
:lol:
Or a reading that means nothing. At least the up pipe would give you an idea of combined temperature, which is also an unusual place to monitor.
Aaron's ej22t: You stole my thunder :wink:
Grant
Post by Grant »
I figured you would do the four way from that airplane place with a sensor for each cylinder. :D
Grant Hughes
Denver, CO
http://www.nocoastmotorsports.net
ciper
Post by ciper »
Im really going to! I plan to get the larger version of the guage though, easier to read.
My current plan is to have my car turbo'd and running by august 1. Then I will install the 4 way EGT
