I'm not sure what was on the oil gallery plugs. It looks like a white material, which is either teflon tape, or more then likely a similar pipe thread sealant.
I used teflon tape. Anyone see any problems with that?
Oil Gallery plug sealant?
yeah, on top of the block, and in front of the block.
They do have an aluminum washer, but there is definitely something on the threads.
Thanks.
I'll see about getting new ones, or just leave them. I'm not overly worried.
If you can't get new ones, I'd look to get copper washers of the same diameter and just use those. Annealed washers like these don't work so well the second time because they're work hardened from the first time.
