91 Leg turbo Rear diff-lsd?
I found a 91 Legacy turbo automatic. I was wondering if the automatics had the rear limited slip diff. Is there any way to tell via vin number or something, since I think the sticker on the rear diff is gone.
yes, it should be LSD.
Does it not have the rear cover on? You should be able to tell by looking at the internals.
no
Well that depends. If your 93 5mt is a turbo then probably yes, unless you did swap or someone else did. If it is a NA then no, it is not the same gearing. (assuming your 93 5mt is a legacy)
91 Pearl White Sport Sedan
2014 Volvo S60 T5
18 KTM 1290 Adventure S
97 Toyota 4Runner SR5 - sold
2002 BMW r1150rt-p - sold
2004 BMW r1200ST - sold
2016 BMW r1200RS - sold
2014 Volvo S60 T5
So your 93 MT (n/a) is 3.90?
The 93 SS should have a 3.90 final drive ratio.
gotcha
