Diamond packs, note what years you know has them
I know that 1995 and 1996 with the 2.2 had the diamond packs we like so much. I also grabbed one from a 94 NA AT Sedan.
edit: Found this accidentally http://www.motec.com.au/drawings/m34.pdf
In case any of you dont know what it looks like Legacy777 site has a great image of one, its the last image in the Engine section
http://www.surrealmirage.com/subaru/pics.html#engine
legacy92ej22t
The first gen MT legacies had the diamond packs. I'm sure there was some disparety, but for the most part, the MT models got the diamond coil packs.
legacy92ej22t
Now my 92 MT turbo coil doesn't actually say hitachi on it but it doesn't say diamond either like my friends 93 na MT.It has the little swoosh symbol and a part # thats it
I've noticed wierd things about my turbo,its japan built,the coil pack and also my injectors don't look pink to me they look white!Whats up with that
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
eastbaysubaru
legacy92ej22t
Ya I had thought that too.But when others talked of how bright the pink was I started wondering.It doesn't look like they've ever been changed. so maybe they are.It's good to know yours aren't real bright,gives me hope
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
My coilpack don't say hitachi or diamond either...just the little logo thingie people talked about. As for my injectors...they are grey.
thanks
Micum
PS: Has anyone here pulled their injectors? I pulled mine and there are two orings that go onto the injector, and with the bottom oring, there was a white hard plastic ring. The company that cleaned my injectors had never seen such a thing, and didn't think it should be on there, what do y'all think? And I have this black rubberish square cut ring (a oring w/ square cross section) that sits inside the rail, on top of the hole for the injector nozzle, below the fuel side feed. The injector sits on top of the square ring...any idea where to get these? could it be replaced with an oring? Are different sized injectors similar enough that other subaru EJ engines with side feed injectors might have the same or similar rail and square cut ring? I have a JDM legacy GT turbo EJ20G...
Sorry for the long repetitive kinda off topic ps, I'm desperate, my car is in peices!
thanks
Micum
Micum
97 Legacy 2.5 GT - mod'd
93 Impreza L AWD (sold)
97 Legacy 2.5 GT (deceased)
98 Legacy Outback (sold)
I just pulled a diamond pack of my friends 92 legacy 5mt parts car...but it was mounted "upside down". The label that says diamond was facing the windsheild. I just put it in my Legacy turbo...I wasn't sure what way to mount it. Does it matter how it sits? Would this affect plug wires, ie would you have to switch around the wires?
thanks
Micum
thanks
Micum
Micum
legacy92ej22t
ok I bought a diamond after work today and this is what it says "diamond F-569 12V use with transistor ignition made in japan 0002762".Is this the right one?I'm sure it is but thought I'd make sure.got it for 25$ is this a good deal?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
Its actually in pretty good shape.I can still read the # for each wire position.Just a tad dirty
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
legacy92ej22t
put it on the other day and it seems like I have much smoother acceleration,no jerking anymore so I'm happy
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
- quasi-mod-o
Yeah, my 91 MT has one, I was also confused about the label facing the windshield, worried about spark timing. But they just put the label on the back of the coilpack, for some odd reason. I've since replaced it with a new one, yes new from the dealer, $80 sumthin in case you're wondering...
You can't really put it on wrong. The correct way to put it on is with the wire harness connector on the passenger side of the intake manifold, as vrg3 stated, but even if you tried to mount it the wrong way, the fact that the wire harness shouldn't be able to reach to the other side should give you a hint
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Matt Monson
- quasi-mod-o
I know this is an old thread, but was reading up on why the diamond is desireable. My MT NA '90 made in USA has a Diamond pack. My Auto Turbo '92 engine does not. Seems to be consistent with the auto/MT theory...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Matt - Yeah, I think that's right. The parts catalog lists one number for non-turbo 5MTs (22433AA370) and another number for turbos and automatics (22433AA360).
Mark - You might as well put it on if it's just lying around. The Diamond pack has a different turns ratio in the coils so it generates a higher spark voltage.
[edited to fix dyslexic name-switching]
