Body weights
JasonGrahn
BTW, That weight includes roughly 50 lbs worth of speaker box in the trunk....give or take 10 lbs. I could weigh it if you really want very specific numbers. I'll have to take it out when I swap fuel pumps.
Also, I don't recall if that includes me in the car. I sort of think it doesn't, because I had to push this button for them to know when to capture the weight.
greg donovan
well that is the wieght for 1 of the chassis asked for.THAWA wrote:BURNED!
Someone lock this thread
jason and i are looking for weights of all the impreza and legacy chassis.
this is the weight of Bob Olson's 98-01 RS open class rally car w/a wrx motor.
3000 full tank, nobody in the car
920 LF
860 RF
610 LR
610 RR
apparently this car ha never been corner wieghted and the battery is still in the battery is still in the stock location.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
00 Impreza RS sedan
I've got AC, no moonroof, sub box in the trunk, amps, etc.
scottzg wrote:
the number is the weight in pounds
fwd
base manual automatic
........2720......2820
L......manual automatic
.......2735.......2835
LS....manual automatic
.......2825......2925
LS2 manual automatic
......2830......2950
4wd
L.....manual automatic
......2925.......3005
LS...manual automatic
......3015.......2095
LS2..manual automatic
......3040........3120
These figures are straight from the 1990 fsm, which does not include the turbo model. I would guess a turbo model would be ~40 lbs heavier
http://bbs.legacycentral.org/viewtopic. ... urb+weight
fwd
4wd
greg donovan
if this is right my stripped 1990 FWD L 5MT weighs in right around 2585 and if i swap in some nice racing seats and then strip out the sound deadening and take a hole saw to the interior of the door shells we could get it down to 2500#.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
Those are curb weights, and not really a true representation of actual weight.
My FWD 90 sedan w/ auto was right around 3000 lbs.
greg donovan
so if you drop the stuff out of the trunk that puts you at 2950. and the AWD auto wieghs about 203 pounds and the AWD manual weighs about 130 pounds. i would imagin that a FWD manual probably weighs in at 110 or less maybe w/out the center diff and the ouptut stuff for AWD.Legacy777 wrote:Those are curb weights, and not really a true representation of actual weight.
96 Impreza L sedan
00 Impreza RS sedan
00 Impreza RS sedan
