Body weights
JasonGrahn
Body weights
Post by JasonGrahn »
Looking for weights and distributions for BC, GC, and GD chassis subarus.
-Jason Grahn
scottzg
Post by scottzg »
2825 55/45 (iirc, its been 2 years) legacy L with trunk battery, almost no fuel, no accessories, 5mt, no spare and a few missing pieces of carpet. Autox trim.
Battery is no longer in the trunk.
THAWA
Post by THAWA »
BURNED!
Someone lock this thread :D
BTW, That weight includes roughly 50 lbs worth of speaker box in the trunk....give or take 10 lbs. I could weigh it if you really want very specific numbers. I'll have to take it out when I swap fuel pumps.
Also, I don't recall if that includes me in the car. I sort of think it doesn't, because I had to push this button for them to know when to capture the weight.
greg donovan
Post by greg donovan »
THAWA wrote:BURNED!
well that is the wieght for 1 of the chassis asked for.
jason and i are looking for weights of all the impreza and legacy chassis.
this is the weight of Bob Olson's 98-01 RS open class rally car w/a wrx motor.
3000 full tank, nobody in the car
920 LF
860 RF
610 LR
610 RR
apparently this car ha never been corner wieghted and the battery is still in the battery is still in the stock location.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
scottzg
Post by scottzg »
why is my car so much lighter than josh's? You have ac and a moonroof josh?
wierd.
I've got AC, no moonroof, sub box in the trunk, amps, etc.
scottzg
Post by scottzg »
so like 200lbs just because of ac, maybe a little more gas, a spare tire, and a nicer stereo? Amazing how it adds up.
scottzg wrote:
the number is the weight in pounds
fwd
base manual automatic
........2720......2820
L......manual automatic
.......2735.......2835
LS....manual automatic
.......2825......2925
LS2 manual automatic
......2830......2950
4wd
L.....manual automatic
......2925.......3005
LS...manual automatic
......3015.......2095
LS2..manual automatic
......3040........3120
These figures are straight from the 1990 fsm, which does not include the turbo model. I would guess a turbo model would be ~40 lbs heavier
http://bbs.legacycentral.org/viewtopic. ... urb+weight
greg donovan
if this is right my stripped 1990 FWD L 5MT weighs in right around 2585 and if i swap in some nice racing seats and then strip out the sound deadening and take a hole saw to the interior of the door shells we could get it down to 2500#.
96 Impreza L sedan
00 Impreza RS sedan
Those are curb weights, and not really a true representation of actual weight.
My FWD 90 sedan w/ auto was right around 3000 lbs.
greg donovan
Legacy777 wrote:Those are curb weights, and not really a true representation of actual weight.
so if you drop the stuff out of the trunk that puts you at 2950. and the AWD auto wieghs about 203 pounds and the AWD manual weighs about 130 pounds. i would imagin that a FWD manual probably weighs in at 110 or less maybe w/out the center diff and the ouptut stuff for AWD.
96 Impreza L sedan
00 Impreza RS sedan
