The engine looks to be in fairly decent shape, miles unknown but estimated between 100k-130k and it's unknown what year it is. I got it from a local used parts place. They say they will warrenty the engine against excessive oil leakage, knock, cracks in the heads/block, etc. The engine had been pulled from a car that got hit in the front right (passenger side). It came complete with intake, injectors, alternator, AC compressor but missing the power steering pump. The oil pan though looks like it has a dent in it but I'm not sure if it's a dent or just a different style. The PS pump bracket is also broken, pressumably in the crash? Though the intake and all shows no signs of exterior damage. Right now it's sitting in the back of my van (family's I guess) and I didn't get to look at it too long before I had to get going.
My plan -
This week I'll get out to the house and clean off the old engine real good and then start taking things off the top of it, alternator, AC compressor. I'll pull off the intake as well since I'm planning on swapping my current intake manifold onto the new engine to try to alleviate any wiring issues. Once I have it cleaned and stripped down I'll address the oil pan issue. My dad doesn't think I need to mess with any seals but everyone (he also doesn't really think my engine needs replaced...???) has told me to replace the main crank seals while the engine is out, so I think I will do that too. After all of that, I should then be ready come Friday to clean my engine real good and start labeling lines and wires and then start disconnecting them. By friday night I hope to have everything ready to actually pull the engine. That I'll do Sat. and then swap my intake, the broken PS pump bracket, and possibly oil pan. I don't forsee that taking all day so by Sat. night I'm planning on having the engine back in the car and starting to hook things back up. Sunday I plan to finish up the swap and get back on the road.
I've got Doug's engine pull tips thread bookmarked and I'll continue reading up on anything I can find until the weekend. Until then I'm going to leave this thread open to any opinions/advice/suggestions you all have to make
Oh, I do plan on taking lots of pics so hopefully I can create a good full NA swap thread for others in the future.
