92 ss suspension question
92whitelegacy
Post by 92whitelegacy »
excuse my noobie question, i know if i search ill find this out, i just dont quite understand what it all means rates, dampering ect ect. im lookin for the best suspension setup to drop my car on its NUTS(exaggeration) i want it low but not crazy low wit the stock ss wheels or wrx wheels. BUT it still has to handle like a champ (cant look good and not smoke dsm's) any sugestiongs? THANX sry for my scrub question ill learn fast i promise
92 ss 275k+mi, kartboy shifter/bushings, gauges. VRG3 FCD II, NGK I'4s, TDO5-16G 4" dp CAT-less 3"tbe 4.11 gears.
jamal
Vendor
Vendor
Post by jamal »
What you should apologize for is your scrub spelling and grammar.
Vague ideas of wanting it low but not too low and to handle well enough to beat dsms isn't going to get you many serious answers.
Spring rate is the force it takes to compress a spring. It requires 200 lbs to compress a 200 lb/in spring one inch. Now go have fun reading the compendium. It's there (along with the search feature) so that we don't have to keep answering the same newbie questions over and over again.
Of course, if you want someone to just tell you what to get, I'll suggest KYB GR2 struts and whiteline control springs. Cheap, easy, and effective.
92whitelegacy
yea its the internet grammar and spelling mean bunk to me :) but thanx for the suggestion on the gr2's. and when i say low but not too low, im generalizing i want a really agressive look without sacrifceing handling? dsms dont have a chance either way its fun to make fun of them though :twisted: but im think maybe like a 1-2 inch drop any suggestions on that would be nice also
scottzg
Post by scottzg »
the 2g dsm's have a much nicer suspension set up. The compendium doesn't list spring heights, but they're all pretty much the same height, from what i've seen. Whiteline stuff with gr2's is a pretty solid budget suspension set up. Generally lowering the car does as many bad things as good to the handling.
dscoobydoo
Post by dscoobydoo »
Just a quick search would have pulled up enough reading for hours.
I run AGX's with H&R springs. very tight and about 1.3 inch drop.
But I also run all upgraded sway bars and strut bars. It is a tight ride. No cush on my car.
you don't want to drop it very far. Subarus are not meant to be dropped.
92whitelegacy
yea, i really like the stance of ur leggy with those 2.5rs wheels. :twisted: so you use agx wit h&r springs? thats a nice stance, i like it i might have to steal your setup idea :twisted:
sillyp
Post by sillyp »
one thing to keep in mind is that gr-2's or agx's will raise the front a bit. I think a nice setup is gr-2's and stock springs in the rear and some rs/wrx take off strut/spring combo's in the front. Little or no drop but a bit stiffer in the front and good handling. Combine that with a whiteline 18-22 rear sway bar and wrx wheels and 205/50's, good stance and excelent versatility. cheap! Not to mention the ease of installation of take off strut assemblies (no compressing springs or disassembly of strut assemblies). Matt Monson has some wrx front take offs for sale at a good price right now (parts shed). But then i like to rally on dirt roads, if you only drive on pavement then go ahead and go lower.
honestly though i'm anti-drop, so guess i prolly should have kept my mouth shut on this thread.
92 5mt AWD
F250 duty
12" Johnson
