WRX rims on my Legacy?
eastbaysubaru
So, my question is... Will I be OK if I run stock WRX tires on my car until I can afford to get new tires for the WRX 16's? I know they're a little larger, apparently .7 inches too large. I'm just curious, because they're all over the place right now and I can't really afford new rims and tires, but it'd sure be nice to kill two birds with one stone.
-Brian
FYI...stock WRX tires are 205-55-16 and stock Leg. Turbo tires are 195-60-15
-Brian
'04 PSM FXT
Aaron's ej22t
Or you could be lucky like me and have a speedo that reads slow with the factory size.
Jay
Jay
For sale -'92 White Legacy Turbo Sedan (US Spec) STi shifter, STi strut Mounts, KYB AGX struts, Eibach Springs, 16" 97 GT rims, Potenza RE950 tires and others.
His - 99.5 Audi A4 1.8 TQMS (Brilliant Yellow) w/ some Mods
You're kidding? My car already goes faster than a stock Legacy SS should... and my speedo's slow? cumagain?Aaron's ej22t wrote:yeah it will work. your speedo will just read a little low. basically, you will be going faster than what your speedo says. the closest size for legacy is a 205/50-16. this is just slightly smaller than stock.
I'm running 205/55/16s Dunlop WinterSport M2s on WRX rims. To answer the 1st question, yeah. they'll fit. And they look DAMN good too. I've only had the car for a couple weeks, and I've had several comments on "Hey, nice rims!" They look nicer than the legacy turbo rims IMO, but not at all *bling* or "rice" or whatever.
but this really has my speedo running slow? damn. I can't wait to get the set of stockers I was promised so I can get some real times.
IggDawg is cool.
-IggDawg
1994 Barcelona Red SVX LSi.
1990 CRX Si (for sale)
I know a little about Subarus.
-IggDawg
Igg,
Try to find one of those speed signs.....where it says your speed is...xxx.
Try and go by it with no one around you and at different speeds to see how acurate your speedo is.
Other way to do this is get a gps unit. It'll tell you your ground speed. Only issue you'd have is the antenna needs line of sight to the satellite so you gotta hold it under the windshield.....unless you have a remote antenna.
Aaron's ej22t
with a incorrect ratio that has a tire size which is too large, your car will actually be slower in acceleration. you will rev lower on the freeway at cruising speeds, and the speedo will read slow. search for a tire calculator and do the calculation of a stock 195/60-15 compared to 205/55-16.
-aaron
-aaron
92 Legacy Turbo \ 5MT \ Silver
eastbaysubaru
From what I understand, you should be fine, unless you have other problems to begin with.
When I put WRX rims and tires on my '93 Legacy Turbo they scrubbed the wheel wells in the rear a tiny bit on sharp turns. I'm pretty sure my rear springs are worn out, though, since I left a lot of weight in the back seat and in the trunk for a long time and never gave the springs a chance to decompress. Until I get new springs I've stuck in little rubber spacers which made the problem go away, although they do kind of affect the spring dynamics...
So unless your springs or struts are worn out, you'll probably be fine. Many people have done WRX wheel swaps.
- quasi-mod-o
I had 14" stock rims to begin with, and now I have 17's. With my low-profile tires on the 17's the diameter is about the same. But should I be worrying about wheel bearings or anything like that?eastbaysubaru wrote:I'm just wondering about the possibility of mechanical problems.
Sorry this is off-topic, btw...
eastbaysubaru
Aaron's ej22t
subyluvr, you don't have to worry about wheel bearings unless you run a really low offset. don't you have rota wheels? IIRC, they are 48 offset. anything less than 46 is probably about where you start having long-term problems. i would recommend staying in between 48-53 offset.
My 16" wheels have +45mm offset......and I haven't had any issues. granted I haven't noticed any smoking wheel wells.....or grinding noises.....so I would assume they are fine.
eastbaysubaru
I just got the wheels on two days ago. They look HOT. Much better than my stock 15's. They make the car feel sooo much better too. I immediately felt a difference the first time I took a tight turn. I'm really excited about them. As soon as I get the new axles in I'll be taking it in for an alignment...hopefully on Monday.
-Brian
Pics to come tomorrow or the next day.
-Brian
'04 PSM FXT
